318 pullys will the line up with a 360. #2132230
08/13/16 09:13 PM
08/13/16 09:13 PM
Canada
Dons Dart Offline OP
Canada
74 Duster with the 318 with power steering.I have look at a 86 Dodge Ram with the 360 4bb,my question will my pullys off my 318 bolt on and line up.For some reason i think the 360 balancer is thicker than the 318 .Any thoughts.
Re: 318 pullys will the line up with a 360. [Re: Dons Dart] #2132450
08/14/16 02:33 AM
08/14/16 02:33 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
They'll work fine
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 318 pullys will the line up with a 360. [Re: 69L78Nova] #2132469
08/14/16 02:59 AM
08/14/16 02:59 AM
mancini & 440 source has crank shims & speedway mtrs & others have pump shims. spacing the alt is easy. the pump "cross" can move in or out a slight bit. use a piece of tubing or a laser pointer in a pulley groove to confirm dead on alignment if in doubt or in a high RPM app
Re: 318 pullys will the line up with a 360. [Re: Dons Dart] #2132484
08/14/16 03:46 AM
08/14/16 03:46 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
they will line up just fine...
Tony
70 AARCuda Vitamin C
Re: 318 pullys will the line up with a 360. [Re: Dons Dart] #2132499
08/14/16 04:27 AM
08/14/16 04:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The problems arise when you try to mix and match the pulleys. If you use a matched set, things are fine since the attachment points are the same.
The factory had a dizzying array of combinations though. P/S or not, A/C or not, Police alternator or not, Smog pump or not...
Re: 318 pullys will the line up with a 360. [Re: Dons Dart] #2132535
08/14/16 10:33 AM
08/14/16 10:33 AM
Canada
Canada
Ok, thanks all,my last build was a 360 in my 69 Dart,witch is gone now.And I am using the pulleys off the 318 Duster,there a matching set.
