Tips & tricks to restore fasteners to Black Oxide Phosphate
#2132167
08/13/16 07:39 PM
08/13/16 07:39 PM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
Some tips and tricks for restoring original fasteners at home to a Black Oxide Phosphate finish. https://youtu.be/7vTn6l5h67AAlways appreciate the positive feedback and thumbs up!
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: Tips & tricks to restore fasteners to Black Oxide Phosphate
[Re: Cuda Cody]
#2132227
08/13/16 09:08 PM
08/13/16 09:08 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Nicely done!
Thumbs up!!
Tom
68 Charger 70 Cuda
[Re: Cuda Cody]
#2132386
08/14/16 12:43 AM
08/14/16 12:43 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Thanks!!!! Nice job! 2 Thumbs up!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: ogopogo]
#2132492
08/14/16 04:08 AM
08/14/16 04:08 AM
Cuda Cody
Vancouver, WA
That's a great suggestions. I still have some RPM that I'll try your idea with. Scott Smith (Harms) also suggested with the SEM bolts (captured washers) that a soak in Evaporust after the wire wheel / media blasting might get even more of the rust off from under the washer. Then a quick rinse and dry off before the Black Oxide should work really good. Both those ideas are great. Thanks for sharing those! I love to learn new ways to do it. pro video ,nice job! I have used the caswell product on my last couple restos and i prefer to use rpm instead of the caswell sealer or wd40 for a flatter more durable finish,just my experience...
[Re: mopars4ever]
#2132904
08/14/16 08:27 PM
08/14/16 08:27 PM
Cuda Cody
Vancouver, WA
I've had a few people tell me they use a clear spray instead of an oil. I'm going to give it a try! Eastwood sells the same type of stuff that I have used for years. Without a good top coating they will rust once exposed to weather. The sealant that comes with it doesn`t hold up to well. I ended up spraying with a coat of satin clear spray.
[Re: Cuda Cody]
#2133041
08/14/16 10:41 PM
08/14/16 10:41 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
I've used RPM as the sealer too - seems to work well.
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: mopars4ever]
#2133574
08/15/16 03:27 PM
08/15/16 03:27 PM
KWF340
Hinckley, Ohio
I used RPM on some stuff on my daily driver and it didn`t hold up at all. It rusted like there wasn`t anything on it. I've seen that too if the coverage isn't good. I think when RPM first came out ECS stated you can wipe off the excess RPM right after application (i.e., while the part was still warm). The logic was that the RPM was already in the "pores" of the metal and wiping off the excess did not remove the RPM in the pores. I tried that and it seemed to provide spotty protection. Now I just apply it and let it be - it's worked fairly well for me.
