Nylon lock nuts
#2127791
08/08/16 12:36 PM
08/08/16 12:36 PM
Posts: 7,506 Az
Crizila
Az
How many times can I reuse them? I have a lot of these on my street car suspension that I make adjustments to now and then - caster, camber, toe, pinion angle, etc.
Fastest 300
Re: Nylon lock nuts
[Re: Crizila]
#2127799
08/08/16 12:53 PM
08/08/16 12:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If they still have good drag to them I will use it... but if you can turn them on 1/2 of the nylon with your fingers... get new ones.. I use a lot of them
Re: Nylon lock nuts
[Re: Crizila]
#2127822
08/08/16 01:27 PM
08/08/16 01:27 PM
Posts: 10,039 MN
JERICOGTX
MN
Where I work, we can reuse them once. After that, throw them away. No sense in reusing something that cost very little, when it's holding a important part of the car together.
69 GTX
68 Road Runner
Re: Nylon lock nuts
[Re: Crizila]
#2127946
08/08/16 03:32 PM
08/08/16 03:32 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Technically, the decision to reuse a lock nut should be based on a "prevailing torque" test. IOW, the torque required to spin the nut before it starts to clamp the components.
There are charts that show the minimum prevailing torque based on diameter and the type of locking device.
Re: Nylon lock nuts
[Re: John_Kunkel]
#2127978
08/08/16 04:20 PM
08/08/16 04:20 PM
MR_P_BODY
To be honest... if its a suspension part that isnt going to be tightened so things move... I'd put a new one on each time... but if its going to be tightened tight then I check them.... I have a drawer of each size of 1/4, 5/16 and 3/8... but on any big stuff or fine thread I have to buy them.. sure isnt like back when I was working
Re: Nylon lock nuts
[Re: MR_P_BODY]
#2128506
08/09/16 09:07 AM
08/09/16 09:07 AM
Posts: 19,493 north of coder
moparx
my opinion on suspension stuff, if unable to use normal nuts with lock washers, is to use the "deformed" style nut, or castle nuts and cotter pins. i usually have to resort to drilling grade 8 bolts for the pin [if used with castle nuts] as well as cutting off of excess thread after i obtain a bolt with the suitable shank length. [no matter which nut is used] i don't like to use a bolt with too short of a shank that lets threads in the pivot area. i realize that those "deformed" style of nuts ruin the bolt threads, but i would rather replace the nuts and bolts during routine maintenance than have them come loose at an unfortunate time. just my opinion and what i feel comfortable with. what i really don't like to see on suspension fasteners is stainless bolts with polished heads. number one, if the head is polished, how do you REALLY know what grade it is, and number two, is the galling tendency stainless has without using something on the threads to prevent that from happening. and even if you use loctite or anti-seize [some even suggest using pepto bismal], there is still a nagging feeling i get that even though it feels tight, did it gall at the proper tightness, or will it gall upon removal and create a real problem removing the fastener[s] ? again, just me.
Re: Nylon lock nuts
[Re: Crizila]
#2128520
08/09/16 09:50 AM
08/09/16 09:50 AM
Posts: 10,039 MN
JERICOGTX
MN
Those "deformed" nuts, are called stover nuts. Stainless hardware has no place in a race cars suspension IMO.
69 GTX
68 Road Runner
Re: Nylon lock nuts
[Re: Crizila]
#2128779
08/09/16 04:20 PM
08/09/16 04:20 PM
Challenger 1
Cincinnati, Ohio
How many times can I reuse them? I have a lot of these on my street car suspension that I make adjustments to now and then - caster, camber, toe, pinion angle, etc. IMO nylon lock nuts are too light duty for a race car. I relate them to household use where they won't be subject to much heat and vibration. I reuse them around the house but would not use them on my cars. Metal lock nuts should be used on cars that are higher than grade 2.
Re: Nylon lock nuts
[Re: Challenger 1]
#2128879
08/09/16 07:32 PM
08/09/16 07:32 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Well all of the airplanes that use them must be light duty? The metal lock nuts are typically used in high heat applications where the nylocks are used in areas that are not subject to rotation. If the bolt is subject to rotation, ie the bolt turns in its application, then you use a castellated nut. How many times can I reuse them? I have a lot of these on my street car suspension that I make adjustments to now and then - caster, camber, toe, pinion angle, etc. IMO nylon lock nuts are too light duty for a race car. I relate them to household use where they won't be subject to much heat and vibration. I reuse them around the house but would not use them on my cars. Metal lock nuts should be used on cars that are higher than grade 2.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Nylon lock nuts
[Re: MR_P_BODY]
#2129770
08/10/16 08:31 PM
08/10/16 08:31 PM
Posts: 7,506 Az
Crizila
Az
To be honest... if its a suspension part that isnt going to be tightened so things move... I'd put a new one on each time... but if its going to be tightened tight then I check them.... I have a drawer of each size of 1/4, 5/16 and 3/8... but on any big stuff or fine thread I have to buy them.. sure isnt like back when I was working All my suspension hardware is grade 8, all big stuff ( 1/2. 5/8, 3/4 on 4 link and front control arms ) and all nylon lock nutted. Guess it's time to spend some $ at www.fastenal.com.
Fastest 300
Re: Nylon lock nuts
[Re: Crizila]
#2129935
08/10/16 11:24 PM
08/10/16 11:24 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use G8 SAE thread and nylocks everywhere. No top locks, no lock washers. If the bolt is in double shear, (4-link, lateral link, motor plate with a limiter), and not subject to high stretching loads, I will use a shorter bolt and the short nylocks. Weight. No hardware store, cheap stuff.
