5.2 - Any Difference Between '93 and '95 Motors? #2125038
08/04/16 05:42 PM
08/04/16 05:42 PM
N.W. Florida
Fat_Mike Online work OP
Fat_Mike  Online Work OP
N.W. Florida
A friend has a lead on a '93 motor for his '95 Dakota. Other than maybe some external stuff, is there anything better, worse or different about the '93 motor?
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: Fat_Mike] #2125049
08/04/16 05:52 PM
08/04/16 05:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Everything should be the same. Did EGR perhaps come/go in that year?
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: DaytonaTurbo] #2125194
08/04/16 08:56 PM
08/04/16 08:56 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
ODBII took out the EGR in 1996, I think, not certain.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: 3hundred] #2125229
08/04/16 09:54 PM
08/04/16 09:54 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Rumor was that the camshaft and torque convertor changed from the 92-93 models. Published values for the 92-93 cam is pathetic, but supposedly, according to a 1994 mopar action article, the 92-93 engines were hotter. Certainly the 92-93 exhaust manifolds are desirable.
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: Fat_Mike] #2125237
08/04/16 10:06 PM
08/04/16 10:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The early manifolds are bigger (better?) The early motor has return style fuel rails.
A lot of sources say they early 5.2 and 5.9 used the same cam specs as the earlier LA TBI engines but with the higher rocker ratio it just ain't true.
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: HotRodDave] #2125439
08/05/16 02:06 AM
08/05/16 02:06 AM
N.W. Florida
N.W. Florida
Got it. Thanks to all for the info!
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: Fat_Mike] #2125801
08/05/16 03:50 PM
08/05/16 03:50 PM
MO
synergyperf Offline
synergyperf  Offline
MO
I love learning these little tidbits of knowledge...
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: synergyperf] #2125878
08/05/16 05:19 PM
08/05/16 05:19 PM
dogdays Offline
dogdays  Offline
But, they never come with any specifics. Dave has said there were several camshafts from those engines with very slightly differing specs.
This is nice to know, but it doesn't help me towards a camshaft selection.
And, if we're really talking about moving the torque peak 200rpm up or down, or same with peak horsepower, will it be enough to notice in a 4500 lb daily driver?
R.
Re: 5.2 - Any Difference Between '93 and '95 Motors? [Re: dogdays] #2126041
08/05/16 08:19 PM
08/05/16 08:19 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
These values from the official Field Service Manuals for Rams indicate that camshaft lifts did change from 1992 to 1993:
http://dodgeram.org/tech/gas/specs/cam.html
But the FSM are not completely free of errors.
I know the 1995 Ram FSM has the wrong drawing, weights and specs for the Magnum 5.9 piston.
5.2 "Advertised" 1994 cam specs
http://dodgeram.org/tech/gas/specs/valve-5_2.htm
5.9 "Advertised" 1994-1997 and 1998-2001 cam specs
http://dodgeram.org/tech/gas/specs/valve-5_9.htm
In the above link for the 5.9 cams i wonder if the year columns should be reversed?
The 1998 and above cam was supposed to be more duration and +15 HP at higher rpm.
