Re: 5.2 - Any Difference Between '93 and '95 Motors?
[Re: DaytonaTurbo]
#2125194
08/04/16 08:56 PM
08/04/16 08:56 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
ODBII took out the EGR in 1996, I think, not certain.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Fat_Mike]
#2125237
08/04/16 10:06 PM
08/04/16 10:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The early manifolds are bigger (better?) The early motor has return style fuel rails.
A lot of sources say they early 5.2 and 5.9 used the same cam specs as the earlier LA TBI engines but with the higher rocker ratio it just ain't true.
[Re: dogdays]
#2126041
08/05/16 08:19 PM
08/05/16 08:19 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
These values from the official Field Service Manuals for Rams indicate that camshaft lifts did change from 1992 to 1993: http://dodgeram.org/tech/gas/specs/cam.htmlBut the FSM are not completely free of errors. I know the 1995 Ram FSM has the wrong drawing, weights and specs for the Magnum 5.9 piston. 5.2 "Advertised" 1994 cam specs http://dodgeram.org/tech/gas/specs/valve-5_2.htm5.9 "Advertised" 1994-1997 and 1998-2001 cam specs http://dodgeram.org/tech/gas/specs/valve-5_9.htmIn the above link for the 5.9 cams i wonder if the year columns should be reversed? The 1998 and above cam was supposed to be more duration and +15 HP at higher rpm.
