Suspension setup for street raicing...Need HELP!
#2125640
08/05/16 12:34 PM
08/05/16 12:34 PM
Posts: 3,638 Oakland, MI
dizuster
Oakland, MI
Hoping some of you street race guys can chime in about setups for racing on true unprepped roads.
Not talking about roll racing, stop light racing, etc... True trans brake release 1/8 mile stuff.
I am going to be doing the Roadkill event on Woodward in 2 weeks.
I'm GUESSING that the boost controller needs to get turned down, two step RPM down as far as I can get it, and loosen the rear shocks up to match the new lower "hit" power.
How about down track? How do you guys know how much power to pour into it, and how fast you can pour it on?
Will the track simply take a g-force limit, and you try to tune the power to get near that through 1st gear?
Power taken out on the 1/2 shift to keep it from spinning the tires?
Unfortunately I race this thing on radials which is obviously not the best marginal track tire, but I at least did buy a brand new set of 275 Pro's for the event.
Love to hear from some of you guys... PM's ok if you want to keep quiet about it.
Re: Suspension setup for street raicing...Need HELP!
[Re: dizuster]
#2125758
08/05/16 03:04 PM
08/05/16 03:04 PM
Thumperdart
State of confusion
Can u run a slick or qtp..........
[Re: dizuster]
#2125793
08/05/16 03:45 PM
08/05/16 03:45 PM
Posts: 8,079 Tulsa OK
Bad340fish
Tulsa OK
Yes A Bias ply tire would be best I am sure. Here is a pretty amazing vid of an 8.50 car getting down the street with Megasquirt traction control. https://youtu.be/FembJNagxOE
68 Barracuda Formula S 340
[Re: dizuster]
#2125835
08/05/16 04:22 PM
08/05/16 04:22 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Put some pinion angle in the rear. I had mine down on my old Duster about 5 degrees( with S/S springs) and the thing hooked on ice. Made a huge, huge difference just adding that shim.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: dizuster]
#2125925
08/05/16 06:28 PM
08/05/16 06:28 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Bias slicks and loose front end with lots of travel.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Bad340fish]
#2126509
08/06/16 12:59 PM
08/06/16 12:59 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Yes A Bias ply tire would be best I am sure. Here is a pretty amazing vid of an 8.50 car getting down the street with Megasquirt traction control. https://youtu.be/FembJNagxOE Very cool!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: dizuster]
#2127057
08/07/16 12:04 PM
08/07/16 12:04 PM
dizuster
Oakland, MI
I thought about leaving in 2nd, but unfortunately my TB won't work in anything else but 1st. I need the TB to build boost.
The motor is pretty weak without the turbo, so it will definitely hook if I turn it down far enough. Just trying to use as much of everything I got to get the car down the track quick.
[Re: dizuster]
#2127072
08/07/16 12:31 PM
08/07/16 12:31 PM
OUTLAWD
Metro Detroit
Any means to fix ballast in the trunk? you are heavy enough, but it might help the initial transfer so you can ramp the power in. There are plenty of spots in "Mexico" where people test...
[Re: farmboy]
#2127216
08/07/16 04:42 PM
08/07/16 04:42 PM
Posts: 4,804 Wichita
GY3
Wichita
I run the 315 drag radials, big engine, little cam, lots of low end grunt. I put 300 lbs, weight in the trunk, and left in second gear. In Kansas City the track started out pretty slick, but was starting to come around later on in the day. Wheelspin was not a problem later on in the day, kinda wish I would have tried a low gear launch. Lack of a power adder is what cost me the win. A dialed in turbo car is hard to beat, but a Nox car is what got to me. Better have your cooling system in top shape. Good luck. farnboy was in the money with a 3rd place finish (despite a 3 way tie for 1st and being 2-0 against the eventual winner) at the Roadkill Nights in KC, FYI.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: B3422W5]
#2127998
08/08/16 04:55 PM
08/08/16 04:55 PM
Posts: 10,091 MN
JERICOGTX
MN
Put some pinion angle in the rear. I had mine down on my old Duster about 5 degrees( with S/S springs) and the thing hooked on ice. Made a huge, huge difference just adding that shim. What in the world does pinion angle have to do with making the car hook?
69 GTX
68 Road Runner
