Re: Lets Talk Break In Oil
[Re: MR_P_BODY]
#2125663
08/05/16 01:02 PM
08/05/16 01:02 PM
fast68plymouth
So. Burlington, Vt.
For flat tappet cam motors its Driven BR exclusively for me.
[Re: MR_P_BODY]
#2125669
08/05/16 01:09 PM
08/05/16 01:09 PM
fury4speed
Second on the BradPenn break in oil , also use regular BradPenn in your engine , www.summitracing.com has these oils and free shipping.
[Re: MR_P_BODY]
#2125837
08/05/16 04:25 PM
08/05/16 04:25 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Brad penn 30 WT. Break in oil and brad penn 10-30 after that.
I also run the crower light weight EDM lifters. Roughly 100 miles so far with only the outer springs. Inner springs are going on tonight and I'm gonna let her rip!
unions....the folks who brought you the weekend!
[Re: MR_P_BODY]
#2126120
08/05/16 09:56 PM
08/05/16 09:56 PM
fast68plymouth
So. Burlington, Vt.
Honestly, when I'm doing most roller motors I don't even bother with a dedicated break in oil...... But I wouldn't argue against it. For the past several years I've been using Brad Penn 15w-40 for the roller motor testing.
[Re: fast68plymouth]
#2126140
08/05/16 10:22 PM
08/05/16 10:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Honestly, when I'm doing most roller motors I don't even bother with a dedicated break in oil...... But I wouldn't argue against it. For the past several years I've been using Brad Penn 15w-40 for the roller motor testing. For my roller engines I dont add anything special and there is no break in.. set the timing and carb and go beat on it.. then change the oil and filter after the week end ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2126308
08/06/16 02:12 AM
08/06/16 02:12 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Valvoline VR1 Racing oil is all I have ever used. I use it to break in my cams and use it for the life of my engines. I do add a bottle of ZINC at break in and oil changes and of course use the manufactures cam lube also at break in. But I have never wiped a cam lobe on any eng. Ron
[Re: MR_P_BODY]
#2126627
08/06/16 05:31 PM
08/06/16 05:31 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
This is the answer I got from Lake Speed at Driven wen I asked about adding break in additive to the BR40 oil:
"The BR40 does not need any extra additives, so I would not recommend using the additive with BR40. It can't help the BR40 work better. It already has the proper balance."
[Re: MR_P_BODY]
#2126634
08/06/16 05:48 PM
08/06/16 05:48 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
... or is too much zinc bad thanks guys Too much ZDDP can cause corrosion inhibitors to become less effective. In general, you don't want to exceed more than 1800 ppm. This probably wouldn't be an issue for break-in, though. A while back, we tested several oils using neutron activation analysis to determine ZDDP content. We published the results, which can be downloaded here. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: momopar]
#2126762
08/06/16 09:52 PM
08/06/16 09:52 PM
MR_P_BODY
That's how I'm doing mine.4-5 Qt VR1 and a bottle of that zddp (?).
Pan holds 8, figure I will be dumpin' the stuff shortly?
The pan I built holds 10 qts plus the filter and remote lines... I only put 8 qts in it to keep it away from the crank ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: NANKET]
#2126776
08/06/16 10:31 PM
08/06/16 10:31 PM
1968RR
Read #1 above. Shelf oils are high detergent, adding you zinc makes you feel good, but the detergents are fighting your additive, not the way to go. Buy the right oil from the start. Specialty oils like Brad Penn and Joe Gibbs are typically lower in detergents than the run-of-the-mill stuff that you can pick up at AutoZone. While Rotella's deisel oil has high ZDDP content, it also has higher detergent concentrations than run-of-the-mill oils intended for use in gasoline engines.
