Re: Can a Edelbrock 650 handle 7 to 9 psi??
[Re: stumpy]
#2125311
08/04/16 11:28 PM
08/04/16 11:28 PM
RapidRobert
May I ask why you are wanting to elim it? You could dial down the reg as is & see how it goes (if that can be done). My eddy 1406 dripped at ~2K with no regulation & that was with a parts house "airtex" mech pump but I have subsequently heard that they put out quite high pressure (for what you think a stock unit would be providing)
[Re: stumpy]
#2125457
08/05/16 02:53 AM
08/05/16 02:53 AM
RapidRobert
hook a vac gauge to manifold vac port & see what your vac is at WOT up thru the gears. if over 1 in hg then a bigger carb will likely benefit you at WOT but how much time do you spend at WOT. street. street/strip. dragger only. which is your situation
[Re: ngpSatellite]
#2125636
08/05/16 12:32 PM
08/05/16 12:32 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Leave the regulator on there. The AFB is not fond of pressures over 6 psi. I normally kept mine between 4-5 psi and never ran the bowls dry, even when blowing through it with the turbos.
[Re: Challenger 1]
#2125691
08/05/16 01:35 PM
08/05/16 01:35 PM
RapidRobert
alot of (fuel) aftermarket gauges ain't accurate but if it don't flood & dont starve then all is good in the 'hood
[Re: RapidRobert]
#2125721
08/05/16 02:08 PM
08/05/16 02:08 PM
Challenger 1
Cincinnati, Ohio
alot of (fuel) aftermarket gauges ain't accurate but if it don't flood & dont starve then all is good in the 'hood I verified my fuel pressure 3 summers ago when I was having trouble with a miss under load. Took my moroso 0-15 psi tire gauge that has been checked at the NHRA nationals many times(my crew would have it checked several times a year for free at the races) and layed it on my outside windshield under the windshield wiper and drove around with it. I had 7 pounds under load and 8-9 psi at idle. I can't get my picture to upload that shows the psi gauge as I am driving down the road because photo bucket has me locked out. I think I owe them money? Turned out that I needed fresh spark plugs, I had like 10K miles on them. My manual choke is hard on them. I am sure of the pressures that I speak of.
[Re: Challenger 1]
#2125778
08/05/16 03:29 PM
08/05/16 03:29 PM
RapidRobert
I can't get my picture to upload that shows the psi gauge as I am driving down the road because photo bucket has me locked out. I think I owe them money? that would do it! Alright, it sounds like you are correct on the readings
[Re: ngpSatellite]
#2125819
08/05/16 04:04 PM
08/05/16 04:04 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I just went through this, too. Do not put more pressure than Edelbrock says it can handle. My AVS can take 6.5 psi, and that's what the Carter pump I use puts out. Even then, I think there's too much pressure. I changed the jets and rods and it still runs very rich. A regulator will be my next step.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
