Re: Lets Talk Break In Oil
[Re: RapidRobert]
#2124594
08/04/16 02:24 AM
08/04/16 02:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
OT, I would confirm the lifters are free to rotate (Hughes "thunk" test) & the usual stuff that you are aware of more than I am, mixture/timing/immediate startup/goosing the throttle. They spin freely since I had to ream each one to fit and it will start with the EFI... I pre set the timing 36* before firing then check it... and I'll take it up to 2000 rpm and move it around some.... they all slide nicely... all at .0015 clearance EDIT plus these have the .012 EDM hole and light weight lifters
[Re: MR_P_BODY]
#2124598
08/04/16 02:38 AM
08/04/16 02:38 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I broke my solid flat tappet in with Joe Gibbs break in oil + Lucas Zinc additive. Also only on the outer valve springs of a double set. I regularly run Lucas Hot Rod 10w-30, with the same zinc additive. Change the oil once a year.
6 years, a few thousand street miles, and well over a hundred passes and I've had zero cam issues.
[Re: MR_P_BODY]
#2124605
08/04/16 02:57 AM
08/04/16 02:57 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Depending on the cam lube used, another thing ive seen people do it put it on the sides of the lifters where they contact the lifter bores. BIG no no alot of that stuff is to ADD friction so the lifters do not slide on the cam lobes.
Mopar to the bone!!!
[Re: MR_P_BODY]
#2124661
08/04/16 09:46 AM
08/04/16 09:46 AM
Posts: 561 USA
B3RE
USA
I don't have a flat tapped but used Lucas 30wt. Got a 2.5 gallon jug of it. Seemed like the rings seated on the first drive. This is just a cam change... engine has about 850 miles on it but the tight LSA didnt like the EFI or should I say it the other way around Mike, Why didn't you go with a wider LSA roller grind? I know there isn't much to choose from in the catalogs, but if I find one that suits the combination, but has a tight LSA, I'll call them and have one ground wider. Comp can usually turn one of these around in a couple weeks, and then the lobe failure worries go away. Just a thought, since you are already set up for a roller.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#2124697
08/04/16 11:04 AM
08/04/16 11:04 AM
Posts: 6,150 Melbourne , Australia
LA360
I used Lucas, it was more available than the Gibbs Driven. I've heard lots of good things about the Gibbs
Alan Jones
[Re: B3RE]
#2124705
08/04/16 11:13 AM
08/04/16 11:13 AM
MR_P_BODY
I don't have a flat tapped but used Lucas 30wt. Got a 2.5 gallon jug of it. Seemed like the rings seated on the first drive. This is just a cam change... engine has about 850 miles on it but the tight LSA didnt like the EFI or should I say it the other way around Mike, Why didn't you go with a wider LSA roller grind? I know there isn't much to choose from in the catalogs, but if I find one that suits the combination, but has a tight LSA, I'll call them and have one ground wider. Comp can usually turn one of these around in a couple weeks, and then the lobe failure worries go away. Just a thought, since you are already set up for a roller. I didnt like a few things on the Comp lifters.. the edm hole is .026.. too big when I got warm my oil pressure was lower than I like plus I PR oil... lots of built in losses.. the edm hole in the Hughes is .012
[Re: ksj]
#2124722
08/04/16 11:44 AM
08/04/16 11:44 AM
Posts: 103 muskegon MI
v cummins
muskegon MI
Gibbs for break in and Valvoline VR1Racing oil after that This has worked well for me. All of my resto. hemi. max wedge. 440s. get this and works well. use the gibbs BR yellow lab. not the HR-2. then the Valvoline. I have also used a lot of rotella in the past
[Re: MR_P_BODY]
#2124942
08/04/16 04:01 PM
08/04/16 04:01 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use the Chrysler cam lube,STP and Rotella,fire it and break in the engine.
[Re: Eric]
#2125125
08/04/16 07:21 PM
08/04/16 07:21 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
The last couple flat tappet this is what I used with great results. I don't think it would hurt to run it all the time.. maybe lose a few horsepower but sure would be good for the cam
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: LA360]
#2125129
08/04/16 07:26 PM
08/04/16 07:26 PM
MR_P_BODY
I used Lucas, it was more available than the Gibbs Driven. I've heard lots of good things about the Gibbs I've been looking around what is out there local... I can get the Lucas break in oil local... I'll look some more to see if Gibbs is easy to get.... now ... with these break in oils do you add any more zinc... or is too much zinc bad thanks guys
[Re: BIGSTROKER]
#2125498
08/05/16 09:36 AM
08/05/16 09:36 AM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I use Comp Break-in oil on engines I do, No problems yet.
The only Carbs I care about are under the hood!
