Re: engine bore
[Re: poly]
#212376
02/02/09 11:50 PM
02/02/09 11:50 PM
RapidRobert
You might contact egge machine shop & see what they have(or can make). It would not be cheap but to get a 413 up & running it might be something to consider.
Re: engine bore
[Re: poly]
#212378
02/03/09 10:20 AM
02/03/09 10:20 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
Okay, makes sense the way you say it, only in 64, the block casting number is the same for 413, and 426, and I was thinking that they had .060 over pistons for the 426, which has you getting in the range of the 440
You can ask the question 600 different ways and the answer will be the same .
The only way you will know exactly how far the block can be safely overbored is AFTER a SONIC CHECK .
Re: engine bore
[Re: poly]
#212379
02/03/09 02:39 PM
02/03/09 02:39 PM
Posts: 2,648 USA
max
super gas
super gas
USA
in the old days it was quite common to bore a 426 +.070 over and use standard bore 440 pistons. as a matter of fact i have a 1964 426 in the garage right now that was done that way.
but as John said, it's best to sonic test the block before doing any excessive boring to see just what you can do.
