Indy intake with NOS spray bar #2122080
07/31/16 06:31 PM
07/31/16 06:31 PM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Purchased this indy rb intake. Has valley pan welded to it with a NOS spray bar mounted in it. Anybody used one like this. trying to figure out solenoids and jetting.
Re: Indy intake with NOS spray bar [Re: rick4106] #2122104
07/31/16 07:10 PM
07/31/16 07:10 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
never seen that done before, i wonder is they had a hood clearance problem? im sure monty will chime in on jet/solenoid combo, id think the nos cheater upgrade would be a good way to do it, it doesent come with a plate, but comes with the bigger solenoids, bigger feed line, etc so it doesent have alot of parts that you dont need in it.
Re: Indy intake with NOS spray bar [Re: rick4106] #2122129
07/31/16 07:57 PM
07/31/16 07:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Only way to know for SURE what it is capable of is to flow test it. Size of bar, size of holes and number of holes all make a difference. It's essentially a plate kit mounted in the plenum, but like a plate, the bars is what matters.
Re: Indy intake with NOS spray bar [Re: rick4106] #2122151
07/31/16 08:40 PM
07/31/16 08:40 PM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Is that something u do monte and what do u charge. Somebody said it might be a old kos intake. Valley was welded to get to lifters without removing head. Has one gas and one nos spraying direct inside of port.
Re: Indy intake with NOS spray bar [Re: rick4106] #2122522
08/01/16 11:51 AM
08/01/16 11:51 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Richard O'Malley (O'Malley Competition, KOS sponsor) used to do that type of stuff.
I'd definitely send it to Monte and have it flowed...otherwise you'll just be guessing. I'd much rather know where to start from the get-go so I didn't hurt anything w/ a left field tune up.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Indy intake with NOS spray bar [Re: rick4106] #2122574
08/01/16 01:24 PM
08/01/16 01:24 PM
AndyF Offline
AndyF  Offline
I had an intake like that once. I started with a new intake which I sent to NOS. They mounted a spray bar in the plenum for me and sold me the matching solenoids. I never used it, ended up selling it at a swap meet.
Re: Indy intake with NOS spray bar [Re: rick4106] #2122601
08/01/16 01:57 PM
08/01/16 01:57 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
My KOS Demon had a O'Malley plate with cross bars that was stamped with something like 250HP. Didn't have any jets in it when I got the car and I am glad I didn't try to turn it on. The jet is where the conical section Is that the hose seals to. Had it flowed and a couple holes dribble instead of spray. Now the manifold just has the fogger.
Why can't you flow test the fuel side with a NOS bottle? Too much pressure for the solenoid to open against?
