Page 1 of 3 1 2 3
Dang it, I broke it. COMPRESSION CHECK 08/07 #2121870
07/31/16 01:04 PM
07/31/16 01:04 PM
Between Houston & Galveston TX
SattyNoCar Online happy OP
SattyNoCar  Online Happy OP
I admittedly drive my Dakota with a heavy foot, but, never literally foot to the floor screaming high RPM's....
In a moment of frustration/panic, I wound the engine pretty tight last week. blush
Now it smokes every time I start it.
Too little time and too hot outside to dig in and diagnose it right now. Aside from the smoky starts, truck feels no different. confused But, it is using oil now.
I'm thinking of buying a long block for it, but, with 166K on everything else, what kind of can of worms would I be opening?
Truck is rust free (not dent free though) and aside from the AC not working, has been a good little truck in the year and a half I've owned it.
Truck has the V6 and I would probably keep it.
Just thinking out loud here. eyes
What would you do? shruggy
John
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2121901
07/31/16 01:45 PM
07/31/16 01:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Lower pan on intake been done on it yet?
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2121940
07/31/16 02:41 PM
07/31/16 02:41 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I would keep it and build a fresh V6 for it. The truck does not owe you anything and whatever you get to replace it will have its own host of gremlins to be sorted.
I have thought several times that I should be selling my '87 and get a newer truck. I have seen a lot of appealing Dodges on CL and they would be perfect for towing a car trailer with the Ramcharger. But I don't need it yet and I also don't have payments either. The '87 runs very well, gas is cheap now, I have a new canopy on it and my dogs are comfortable and secure in it.
BTW 166K is not a lot of miles for a truck.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2121941
07/31/16 02:41 PM
07/31/16 02:41 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Texas without AC? You are tougher than I am .....LOL
Re: Dang it, I broke it. Do I fix or move on....... [Re: buildanother] #2121945
07/31/16 02:47 PM
07/31/16 02:47 PM
One of the first things I did. I used the Hughes kit.
No A/C in this hasn't been too bad. My wagon has no A/C and that was BRUTAL! panic
John
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2121956
07/31/16 03:04 PM
07/31/16 03:04 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Time to swap in a 318 or 360. More power and no worse on fuel. Go to to the salvage yard and find a low mile motor and stick it in there.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Dang it, I broke it. Do I fix or move on....... [Re: 71yelladustr] #2122009
07/31/16 04:42 PM
07/31/16 04:42 PM
If I go with the V8, do I need to swap the trans too?
Then there's the matter of wiring and computer. work
I looked underhood one day and thought "Hmmmm... a modern Hemi would fit".....but reality is that would be WAY beyond my budget.
Or would it? devil
John
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122030
07/31/16 05:18 PM
07/31/16 05:18 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Depends mostly on wether its new enough to have electronic governor. that showed up in 96 or 97 I believe.
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122052
07/31/16 05:58 PM
07/31/16 05:58 PM
Missouri U.S.A.
Missouri U.S.A.
The trans will bolt right up to a v-8. The motor mounts, accessories and exhaust bolt on. You will need a v-8 PCM and possibly a harness. I was cheap and used the existing
V-6 harness when I did mine. Just had to add 2 injector driver wires to make it work.
10.02@134
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122072
07/31/16 06:20 PM
07/31/16 06:20 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
let it go---buy another with a v8......
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122121
07/31/16 07:42 PM
07/31/16 07:42 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'd drive it til it drops, if it all of a sudden started smoking I'd guess it's probably the plenum gasket, it's worth a check. The chance of the engine being hurt would be pretty minimal I'd guess
Re: Dang it, I broke it. Do I fix or move on....... [Re: WO23Coronet] #2122139
07/31/16 08:18 PM
07/31/16 08:18 PM
I guess I'd be disappointed if it was the plenum gasket since I replaced it with the kit from Hughes.
When I did the gasket swap, I was shock to find that the manifold was basically just resting on the engine. NONE of the intake manifold bolts required a wrench to remove, ALL were loose and removed by hand. Once all the bolts were removed, the manifold simply lifted off. There was no work required to break a seal. Aside from a slightly high idle (and evap controls that didn't work) the truck seemed to run fine. shocked shruggy
Re: Dang it, I broke it. Do I fix or move on....... [Re: 71yelladustr] #2122242
07/31/16 11:08 PM
07/31/16 11:08 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
He's right.
There's lots around, they are dirt cheap and the miles are low. Not only that, but I think you will get your money back at re-sale time: you'll have the only 360 Dakota in the classifieds and people will want it!
Mo' Farts
Moderated by "tbagger".
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122244
07/31/16 11:10 PM
07/31/16 11:10 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Oh, and of course I never forgot: you shoulda dumped it and bought that white truck.................like I told ya to. wink
Hee hee, just kidding! Shaddup right? biggrin
Mo' Farts
Re: Dang it, I broke it. Do I fix or move on....... [Re: Grizzly] #2122254
07/31/16 11:17 PM
07/31/16 11:17 PM
catfight
laugh2
But, seriously, earlier when I asked about if I need to swap the transmission, I meant would it handle the added power of a V8?
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122282
07/31/16 11:52 PM
07/31/16 11:52 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I think you're okay. If the weakest one you have is the 904 based one (42 or 44RH/RE) it should'nt be an issue. Actually, better than the 727 based power-sucking turds (46RE/RH).
Mo' Farts
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122507
08/01/16 11:42 AM
08/01/16 11:42 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Around here those trucks probably sell for less then $2,000. I would just find another truck with a V8 this time. I wouldn`t dump any money into it if it were me.
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122674
08/01/16 03:13 PM
08/01/16 03:13 PM
places
79powerwagon Offline
places
You can buy a LOT of oil for that same money. Drive it until it's dead (and that that won't be for a LONG time!)
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2122916
08/01/16 09:35 PM
08/01/16 09:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I guess the question is, how much oil is it going through?
That would be the deciding factor. Might be a good time to run a compression test to see if you broke rings or piston ring lands. If the compression test shows OK, you probably blew out the valve seals or the bottom intake gasket.
I over revved the 3.9 in my coupe when I was out playing one day. Even after that, it ran nearly a full year before I grew concerned enough I replaced it. That motor had a pretty sorted history to begin with, and 149K miles on it. I replaced it with another 3.9 (I bought a wrecked truck with a good motor for cheap). That replacement used motor uses a quart of oil about every 1,000 miles when driving around town (even nearly dead, the original motor didn't use oil).
The "new" motor has 118K miles and has had a timing belt replaced.
The truck I bought (for then scrap price, $275) has nearly paid for itself from parts I've sold off, I'm keeping it around in case I need something else, too bad the frame was bent so badly.
Even with a nearly free replacement motor, I have $300-$400 in stuff I've replaced with the motor (the while I'm here syndrome).
I'd run your current motor until it shows signs that concern you. That may be a very long time. A running driving Dakota (of that era) that moves down the road (even with a smoking motor) will bring $1,000 here, parts trucks still bring $500. Run it until it dies, then sell it to someone building an old car or truck. Gene
Re: Dang it, I broke it. Do I fix or move on....... [Re: poorboy] #2123065
08/02/16 12:09 AM
08/02/16 12:09 AM
I don't see a lot of smoke, but,admittedly its hard to watch the tailpipe all the time.
Usually it uses about half a quart between oil changes (3500-4000 miles), its gone down half a quart in about 200 miles since this happened.
And today I (briefly) heard what sounded like piston slap? Not 100% sure, but, it was definitely a sound I haven't heard before.
Prices on Dakotas around here vary widely (by huge margins), no rhyme or reason. It's VERY rare to see one below $800 no matter how trashed it is.
I almost scored another '93 for cheap last year, but the owner wouldn't budge on the price. The truck ran good but had a blown trans, they were asking $650, I had $500 cash and honestly couldn't go higher at the time. They junked the truck instead. frowwn I guess Pick-A-Part gave them more than I could.
Page 1 of 3 1 2 3
