97 Dodge 1500 won't accelerate #2119513
07/28/16 12:15 AM
07/28/16 12:15 AM
Saskatchewan, Canada
barracudabob Offline OP
Just bought a 97 Dodge Ram 1500 with a 3.9 auto. It will accelerate to about 30 mph, and no more. Engine is still running, but not speeding up. No codes, and no check engine lites on. Where do i start checking?
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2119552
07/28/16 12:56 AM
07/28/16 12:56 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the battery and let it sit for a short while then try it again. It sounds like it's in limp mode. If it's a trans causing it to go into limp it won't give you a code or a light you can read without the trans reader.
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2119892
07/28/16 03:49 PM
07/28/16 03:49 PM
Guitar Jones Offline
A 97 with a 3.9 should have a 42RE trans. Does the transmission shift or just stay in one gear. Does the engine sound like it's laboring or is it revving high?
Re: 97 Dodge 1500 won't accelerate [Re: Guitar Jones] #2120086
07/28/16 07:49 PM
07/28/16 07:49 PM
Trans shifts up and down no problem. The engine just seems to flat spot. push on the accelerator, and nothing, no bucking, backfiring, nothing.
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2120163
07/28/16 09:39 PM
07/28/16 09:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Cat
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2120845
07/29/16 07:29 PM
07/29/16 07:29 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
In 73-75, at a Service station I worked at, we had 4 cars that had the same problem.. All 4 turned out to be collapsed exhaust pipes..
Inner and outer tubing, and the inner had collapsed and blocked the exhaust..
After the 1st one, the rest were a lot easier to diagnose...
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2121011
07/30/16 12:16 AM
07/30/16 12:16 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Check for a restricted catalytic converter
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2121329
07/30/16 03:00 PM
07/30/16 03:00 PM
I concur, clogged exhaust.
Re: 97 Dodge 1500 won't accelerate [Re: Guitar Jones] #2121660
07/31/16 12:33 AM
07/31/16 12:33 AM
Cleaned the catalytic converter out, and voila, no more problem! Thanks for the advice!
