Re: My 63 Dodge 330 Project:
[Re: GY3]
#2117594
07/25/16 09:06 PM
07/25/16 09:06 PM
Posts: 4,687 Wichita
GY3
Wichita
I broke a Spicer u-joint on the last pass of the night about a week ago at the track. The prep was really good and I was trying to leave up against the convertor. Gonna pull the transmission, check the sprag and replace the 8 3/4 with the Dana 60 I mentioned a few months ago. The cone sure-grip lasted all of 2,000 miles and was starting to give up the ghost so it was time.
I never planned on making this much power or I never would have built and 8 3/4. The new Dana will have a spool.
The best thing was this was the first time I had trailered the car instead of driving it so it made for less of a hassle.
[Re: GY3]
#2117995
07/26/16 11:31 AM
07/26/16 11:31 AM
Posts: 1,067 Newton, KS
70B5Cuda
Newton, KS
The best thing was this was the first time I had trailered the car instead of driving it so it made for less of a hassle. Good thing you just bought that new trailer! Mmmmmm.....Dana 60....
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#2119202
07/27/16 05:39 PM
07/27/16 05:39 PM
GY3
Wichita
The best thing was this was the first time I had trailered the car instead of driving it so it made for less of a hassle. Good thing you just bought that new trailer! Mmmmmm.....Dana 60.... The parts from Cass (Dr. Diff) arrived today! This should fix the sure-grip issues!
[Re: GY3]
#2119209
07/27/16 05:59 PM
07/27/16 05:59 PM
GY3
Wichita
Axles with screw in studs! Whooo! Try and break THIS Mr. 505" monster!
[Re: 70B5Cuda]
#2119212
07/27/16 06:06 PM
07/27/16 06:06 PM
GY3
Wichita
The best thing was this was the first time I had trailered the car instead of driving it so it made for less of a hassle. Good thing you just bought that new trailer! Mmmmmm.....Dana 60.... farmboy was making fun of me calling it a trailer queen.
[Re: GY3]
#2121300
07/30/16 02:17 PM
07/30/16 02:17 PM
GY3
Wichita
POS 8 3/4 removed and Dana is at the race shop getting ends installed and pinion setup.
[Re: GY3]
#2126915
08/07/16 01:50 AM
08/07/16 01:50 AM
GY3
Wichita
Race shop cut off floating ends, installed 8 3/4 ends, narrowed to stock '69 B-body housing width and setup my 3.54 ring and pinion. $400 with tax for that, $295 for axles, $125 for spool, the ends were free as we're the perches. I have $60 in the housing that came with extra 4.10 gears and I'm reusing the old brakes off the 8 3/4 so I'm into this thing dirt cheap!
[Re: GY3]
#2127135
08/07/16 02:16 PM
08/07/16 02:16 PM
GY3
Wichita
Made a little more progress. I'm pretty much as far as I can go mocking together before welding spring perches. Need to move axle to the left slightly..
[Re: GY3]
#2132026
08/13/16 03:55 PM
08/13/16 03:55 PM
GY3
Wichita
My neighbor helped me set the pinion angle and welded on the spring perches. I painted it last night.
[Re: GY3]
#2132031
08/13/16 04:00 PM
08/13/16 04:00 PM
GY3
Wichita
We made new brake lines to fit. Really happy with the way they turned out.
[Re: GY3]
#2132747
08/14/16 04:52 PM
08/14/16 04:52 PM
GY3
Wichita
All installed and ready to go. I still need to bleed the brakes.
[Re: GY3]
#2133190
08/15/16 01:25 AM
08/15/16 01:25 AM
GY3
Wichita
Pulled apart the transmission. The sprag looks fine. All I'm out is time and cost of gaskets and filter for peace of mind!
[Re: GY3]
#2133818
08/15/16 08:40 PM
08/15/16 08:40 PM
GY3
Wichita
I replaced a few steels that were blued, put in a bronze thrust washer and cleaned up some stuff. Back together and got the driveshaft back from the shop, so it's ready to go back in! I plan on racing this weekend so the thrash is on!
[Re: GY3]
#2137603
08/21/16 01:04 AM
08/21/16 01:04 AM
GY3
Wichita
Raced the HAMB Drags this weekend. I ran 11.42, 11.41, 11.41 and 11.41 all at ~118 mph. The car is deadly consistent and I even tried to remove the air filter to see if it made a difference. The result? 11.41. It ran really good with no issues despite having it scattered all over the shop floor and a new rearend going in it. The air was really humid with a light headwind. It did run a new best 60 ft. of 1.59.
[Re: GY3]
#2145374
09/01/16 02:05 PM
09/01/16 02:05 PM
GY3
Wichita
I was browsing a few pics from our local track and came across this pic. It surprised me because I never knew it was pulling the left front wheel! This was taken the night I broke the rear u-joint. I did try one of Streetwize's ported Street Dominator intakes this past weekend. That and no other changes netted me an 11.32 @ 119 mph at 3500 DA! It picked up a tenth and a mph over last weekend just like Bobby said it would!
[Re: GY3]
#2146685
09/03/16 10:22 AM
09/03/16 10:22 AM
GY3
Wichita
11.19 @ 121mph last night!
[Re: GY3]
#2166020
10/01/16 06:06 PM
10/01/16 06:06 PM
GY3
Wichita
Won 1st place and $300 in the '64 and earlier nostalgia races today at my local track!
