Page 13 of 26 1 2 11 12 13 14 15 25 26
Re: My 63 Dodge 330 Project: [Re: GY3] #2086206
06/05/16 05:59 AM
06/05/16 05:59 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
11.28 @ 120 new best e.t. tonight!
Spanked a Procharged late model Corvette in the final grudge night race.
Re: My 63 Dodge 330 Project: [Re: GY3] #2117594
07/25/16 09:06 PM
07/25/16 09:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I broke a Spicer u-joint on the last pass of the night about a week ago at the track. The prep was really good and I was trying to leave up against the convertor. Gonna pull the transmission, check the sprag and replace the 8 3/4 with the Dana 60 I mentioned a few months ago. The cone sure-grip lasted all of 2,000 miles and was starting to give up the ghost so it was time.
I never planned on making this much power or I never would have built and 8 3/4. The new Dana will have a spool.
The best thing was this was the first time I had trailered the car instead of driving it so it made for less of a hassle.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2117995
07/26/16 11:31 AM
07/26/16 11:31 AM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
Good thing you just bought that new trailer! Mmmmmm.....Dana 60....
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: My 63 Dodge 330 Project: [Re: 70B5Cuda] #2119202
07/27/16 05:39 PM
07/27/16 05:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The parts from Cass (Dr. Diff) arrived today! This should fix the sure-grip issues! wrench
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2119209
07/27/16 05:59 PM
07/27/16 05:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Axles with screw in studs! Whooo!
Try and break THIS Mr. 505" monster! laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: 70B5Cuda] #2119212
07/27/16 06:06 PM
07/27/16 06:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
farmboy was making fun of me calling it a trailer queen. realcrazy
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2121300
07/30/16 02:17 PM
07/30/16 02:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
POS 8 3/4 removed and Dana is at the race shop getting ends installed and pinion setup.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2126915
08/07/16 01:50 AM
08/07/16 01:50 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Race shop cut off floating ends, installed 8 3/4 ends, narrowed to stock '69 B-body housing width and setup my 3.54 ring and pinion. $400 with tax for that, $295 for axles, $125 for spool, the ends were free as we're the perches. I have $60 in the housing that came with extra 4.10 gears and I'm reusing the old brakes off the 8 3/4 so I'm into this thing dirt cheap!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2127135
08/07/16 02:16 PM
08/07/16 02:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Made a little more progress. I'm pretty much as far as I can go mocking together before welding spring perches. Need to move axle to the left slightly..
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2132026
08/13/16 03:55 PM
08/13/16 03:55 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My neighbor helped me set the pinion angle and welded on the spring perches. I painted it last night.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2132031
08/13/16 04:00 PM
08/13/16 04:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We made new brake lines to fit. Really happy with the way they turned out.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2132747
08/14/16 04:52 PM
08/14/16 04:52 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
All installed and ready to go. I still need to bleed the brakes.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2133190
08/15/16 01:25 AM
08/15/16 01:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Pulled apart the transmission. The sprag looks fine. All I'm out is time and cost of gaskets and filter for peace of mind!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2133818
08/15/16 08:40 PM
08/15/16 08:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I replaced a few steels that were blued, put in a bronze thrust washer and cleaned up some stuff. Back together and got the driveshaft back from the shop, so it's ready to go back in! I plan on racing this weekend so the thrash is on!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2135577
08/18/16 12:59 AM
08/18/16 12:59 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I made a few shakedown passes on the street tonight and all is well. drive
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2137603
08/21/16 01:04 AM
08/21/16 01:04 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Raced the HAMB Drags this weekend. I ran 11.42, 11.41, 11.41 and 11.41 all at ~118 mph. The car is deadly consistent and I even tried to remove the air filter to see if it made a difference. The result? 11.41. smile
It ran really good with no issues despite having it scattered all over the shop floor and a new rearend going in it.
The air was really humid with a light headwind.
It did run a new best 60 ft. of 1.59.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2145374
09/01/16 02:05 PM
09/01/16 02:05 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I was browsing a few pics from our local track and came across this pic. It surprised me because I never knew it was pulling the left front wheel! This was taken the night I broke the rear u-joint. I did try one of Streetwize's ported Street Dominator intakes this past weekend. That and no other changes netted me an 11.32 @ 119 mph at 3500 DA! It picked up a tenth and a mph over last weekend just like Bobby said it would!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2146685
09/03/16 10:22 AM
09/03/16 10:22 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
11.19 @ 121mph last night!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #2161100
09/24/16 10:34 PM
09/24/16 10:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I got to knock another item off the bucket list!
I've wanted to race Heartland Park for years and attended national NHRA events there. The facility is amazing and we had lots of fun.
11.31 @ 119 mph best. Spot on for the weather!
Re: My 63 Dodge 330 Project: [Re: GY3] #2166020
10/01/16 06:06 PM
10/01/16 06:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Won 1st place and $300 in the '64 and earlier nostalgia races today at my local track!
'63 Dodge 330
11.19 @ 121 mph
