68 Barracuda Super Stock Hood
#2116814
07/24/16 08:32 PM
07/24/16 08:32 PM
Posts: 815 PNW
Danan
PNW
Does anyone have detailed pictures of a factory hood that depict how the scoop was attached to the hood, and/or pictures of the underside air box area?
Was the scoop a separate part that was then grafted (glued? Bolted?) on, or were the hoods made as a single piece?
I know Lead Sled, Glasstek, AAR/Stinger, and Unlimited make hoods, but which one(s) are closest to original? I'm not looking for a race weight hood; I want a stock weight piece.
Thanks in advance for any input.
Re: 68 Barracuda Super Stock Hood
[Re: Danan]
#2117252
07/25/16 01:14 PM
07/25/16 01:14 PM
Posts: 43,579 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here is a pic right after it was delivered.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Danan]
#2118072
07/26/16 01:33 PM
07/26/16 01:33 PM
Rhinodart
Rhinotruck
Rhinotruck
No, the scoop is molded into the hood and comes as one piece. This is how they were made from the factory. The reason the AAR hood is two pieces is that the scoops can be sold separately to mount on steel hoods if desired.
A-Body's RULE!
[Re: Danan]
#2128255
08/08/16 10:43 PM
08/08/16 10:43 PM
Posts: 16,489 On the run…
BloFish
On the run…
Do you still have that 69 barracuda rhino?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
