68 Barracuda Super Stock Hood #2116814
07/24/16 08:32 PM
07/24/16 08:32 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Does anyone have detailed pictures of a factory hood that depict how the scoop was attached to the hood, and/or pictures of the underside air box area?
Was the scoop a separate part that was then grafted (glued? Bolted?) on, or were the hoods made as a single piece?
I know Lead Sled, Glasstek, AAR/Stinger, and Unlimited make hoods, but which one(s) are closest to original? I'm not looking for a race weight hood; I want a stock weight piece.
Thanks in advance for any input.
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2116905
07/24/16 11:10 PM
07/24/16 11:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Kramer has the best hood on the market, and it is priced accordingly. I have a 68 Dart hood from him and it is very nice. up
http://kramerauto.com/search.asp?pg=1&stext=fiberglass+hood&sprice=&stype=&scat=
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2116933
07/24/16 11:51 PM
07/24/16 11:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As far as who makes nice 'glass hoods, only ones I've been impressed with so far are AAR's. I don't know who makes Kramer's and haven't seen his, but I've seen or worked with the other names mentioned.
Re: 68 Barracuda Super Stock Hood [Re: topside] #2116990
07/25/16 12:47 AM
07/25/16 12:47 AM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Rhinos art: thanks for the updated info. I called them several times over the years and they seemed to be out of the hood business. I'll give them another shout. Do you happen to have any pictures of your hood?
Topside: I've been impressed with AAR's quality as well.
Thanks for the input!
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2117252
07/25/16 01:14 PM
07/25/16 01:14 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is a pic right after it was delivered.
A-Body's RULE!
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2117970
07/26/16 10:49 AM
07/26/16 10:49 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
I too would like to know those same questions. I have purchased my front end from AAR/Stinger for my Barracuda clone, and I am very impressed with the construction, weight and finish of all the parts. But the scoop is a separate piece, and will be fitting it to the hood soon. So I need to know how the originals were finished.
Re: 68 Barracuda Super Stock Hood [Re: DUSTER_340] #2118049
07/26/16 01:01 PM
07/26/16 01:01 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Thanks for the picture Rhinodart. It appears that the scoop is a separate piece that is attached (screwed? Bonded?). To the flat hood. Does the Kramer hood have the area inside the scoop cut out or is that something the buyer performs?
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2118072
07/26/16 01:33 PM
07/26/16 01:33 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No, the scoop is molded into the hood and comes as one piece. This is how they were made from the factory. The reason the AAR hood is two pieces is that the scoops can be sold separately to mount on steel hoods if desired.
A-Body's RULE!
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2118333
07/26/16 06:19 PM
07/26/16 06:19 PM
Frederick , MD
GibW340 Offline
GibW340  Offline
Frederick , MD
In the mid 1980s I one bought a 68 Barracuda fiberglass hood from a guy in Baltimore- he said was original factory piece made by Anderson Industries (Ai Fiberglas) in Baltimore- all one piece and hood pins only
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2118363
07/26/16 07:04 PM
07/26/16 07:04 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Friend of mine has a Lo23 Dart. And Although I cant guarantee it, I would bet it still has its original hood.
Next time I am there,,,I'll have to lift it up and ck the bottom side
Re: 68 Barracuda Super Stock Hood [Re: gtx6970] #2118448
07/26/16 08:47 PM
07/26/16 08:47 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Thanks! Under hood pics would be greatly appreciated
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2118479
07/26/16 09:14 PM
07/26/16 09:14 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I can take more pics, but there are a couple in Devil's and Mastershakes posts on the Belvidere Mopar Happening post in the General section.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2113024
A-Body's RULE!
Re: 68 Barracuda Super Stock Hood [Re: Danan] #2128255
08/08/16 10:43 PM
08/08/16 10:43 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Do you still have that 69 barracuda rhino?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 68 Barracuda Super Stock Hood [Re: BloFish] #2129172
08/10/16 01:05 AM
08/10/16 01:05 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No, I sold it to a guy who cut it up for parts to restore one he was working on. I got the rear window back still attached to the window frame! laugh2
A-Body's RULE!
