Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed
[Re: 70B5Cuda]
#2757222
03/29/20 12:39 PM
03/29/20 12:39 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
wow great job kid . so over the top . I love the color . you gave me a great idea for my front suspension brace . I will be bending up 1/4 inch and 1/8th inch plate tomorrow. I am splitting mine over 2 inches in the 1/4 and 1 inch in the door.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: 76orangewagon]
#2770682
05/03/20 08:28 AM
05/03/20 08:28 AM
Posts: 1,075 Newton, KS
70B5Cuda
Newton, KS
Thanks all! The 6.1L engine and TR6060 transmission are mated and on the RMS K frame. The engine is a 50K mile factory built short block. I added an Arrington cam shaft and CNC ported heads. The intake manifold has also been ported. From the factory it was rated at 425hp. It should comfortably make 500hp. ![[Linked Image]](https://i.imgur.com/MXGWqtth.jpg) ![[Linked Image]](https://i.imgur.com/yjHrroah.jpg) Holley wiring harness added ![[Linked Image]](https://i.imgur.com/LGNyz8Uh.jpg)
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: DynoDave]
#2772533
05/08/20 03:56 PM
05/08/20 03:56 PM
Posts: 4,927 Wichita
GY3
Wichita
Looking forward to seeing this one on the road!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#2772768
05/09/20 08:59 AM
05/09/20 08:59 AM
70B5Cuda
Newton, KS
Looking forward to seeing this one on the road! Me too!!!! Rear suspension is loaded! The axles are from DSS and they slipped right in. ![[Linked Image]](https://i.imgur.com/sUD4JwRh.jpg) ![[Linked Image]](https://i.imgur.com/9wIEqh2h.jpg)
[Re: 76orangewagon]
#2780481
06/01/20 06:03 PM
06/01/20 06:03 PM
70B5Cuda
Newton, KS
I love seeing a quality build...That thing is awesome...great job. Thanks! Wiring and plumbing in progress... ![[Linked Image]](https://i.imgur.com/tfOGhtFh.jpg)
[Re: 70B5Cuda]
#2780897
06/02/20 08:08 PM
06/02/20 08:08 PM
Superfreak
Superfreak
