Page 1 of 7 1 2 3 4 5 6 7
car won't 60 foot video #2117591
07/25/16 09:04 PM
07/25/16 09:04 PM
birdtracker Offline OP
https://www.youtube.com/watch?v=b2gEtOJ4Qdo
472, powerglide, ladder bars,tryed a 5000 stall convertor and 5800. Tire pressure is 7psi. Tryed leavin at 3000, 4000, 4800 and 5000 with very little change. Once the car is in high gear its on. Looking for suggestions. Thanks. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2117598
07/25/16 09:14 PM
07/25/16 09:14 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
What rpm r u leaving off the t-brake. Seems flat.
Re: car won't 60 foot video [Re: birdtracker] #2117602
07/25/16 09:21 PM
07/25/16 09:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What shocks... it does seem very flat like the
power isnt there.. whats your timing at
wave
Re: car won't 60 foot video [Re: MR_P_BODY] #2117613
07/25/16 09:34 PM
07/25/16 09:34 PM
timing is 36, distrubutor is locked. I tryed leaving from an idle, 3000, 4000, 4,800 and 5000. something is amiss thanks. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2117622
07/25/16 09:43 PM
07/25/16 09:43 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Looks to me like it's dead hooking and bogging it down.
Re: car won't 60 foot video [Re: birdtracker] #2117642
07/25/16 10:02 PM
07/25/16 10:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It just looks like the motor is numb at the hit.
What are the 60' times anyway?
ET & speed?
Timing, jetting, float level, cam size, low gear ratio, etc...... Could be any of those things or more.
Re: car won't 60 foot video [Re: fast68plymouth] #2117649
07/25/16 10:04 PM
07/25/16 10:04 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Converter way too tight
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: car won't 60 foot video [Re: WHITEDART] #2117655
07/25/16 10:09 PM
07/25/16 10:09 PM
I had a 5,000 stall convertor in it, and put a 5800 and the 60 foot didn't change. 1.65. Will run very consistant 6.55s in the 1/8 at 119. Plan on going to Norwalk just to experiment. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2117658
07/25/16 10:11 PM
07/25/16 10:11 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
What motor/cam/carb?
[image][/image]
Re: car won't 60 foot video [Re: birdtracker] #2117676
07/25/16 10:24 PM
07/25/16 10:24 PM
472, 690 Comp roller, and 1050 Dominator. I started with 92 squared jets and went to 97. Back to 93 front and 94 rears. I have not tryed a different carb. It starts great when cold, 2 pumps and fires right up, when hot it takes awhile of cranking but starts. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2117698
07/25/16 10:43 PM
07/25/16 10:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mph looks high for the time. Looks like the cam is retarded. Converter to tight. What gear? How tall a tire? When does it go into high? 472, wedge or Hemi? 3.90 or 4.15 crank? If Hemi that could be your problem, needs more gear. All a guess until more info.
Re: car won't 60 foot video [Re: cudaman1969] #2117709
07/25/16 10:50 PM
07/25/16 10:50 PM
wedge 3.92, 14X32 and 4:10s. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2117713
07/25/16 10:55 PM
07/25/16 10:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It looks to me like the sprag in the converter may be wounded, no torque multiplication.
Doug
Re: car won't 60 foot video [Re: birdtracker] #2117734
07/25/16 11:09 PM
07/25/16 11:09 PM
sgcuda Offline
sgcuda  Offline
4.10 is a low gear to work with a glide. 4.56 would be much better for a mid to high 9 second car.
[image][/image]
Re: car won't 60 foot video [Re: birdtracker] #2117795
07/26/16 12:20 AM
07/26/16 12:20 AM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
could trans low gear clutches gone away,,
Re: car won't 60 foot video [Re: birdtracker] #2117885
07/26/16 02:19 AM
07/26/16 02:19 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Needs 4.88s
Re: car won't 60 foot video [Re: FastmOp] #2117901
07/26/16 03:11 AM
07/26/16 03:11 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By FastmOp
Needs 4.88s
Minimum, could go 5.12 if just running eights. You don't have the hp to run 4.10s
Re: car won't 60 foot video [Re: birdtracker] #2117904
07/26/16 03:28 AM
07/26/16 03:28 AM
Two things come to mind on this, is the shifter adjusted so it is in first only? The second thing is the reaction shaft is loose in the converter from the front pump. My car had that happen last year and again this weekend, I think runaway The car lost a bunch of ET and MPH all of a sudden after stumbling on the line and looseing a bunch of 60 ft whiney scope
Let us know what you find, I've seen several cars leave like that when the shifter cable wasn't adjusted so the pin on the cable would slide in and out of the shifter arm in first gear, the shifter arm would move a little bit when you pulled the cable end pin out of the arm work I've seen the same thing on torqueflytes, there leaving in two gears, not worth a hoot shruggy
Re: car won't 60 foot video [Re: birdtracker] #2117913
07/26/16 04:25 AM
07/26/16 04:25 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Needs 4.88's and a custom converter. Ever dynoed the engine and optimized the tune?
Re: car won't 60 foot video [Re: birdtracker] #2117960
07/26/16 10:31 AM
07/26/16 10:31 AM
an8sec70cuda Offline
32" tire, powerglide...that thing needs a lot more gear than 4.10. We've run up to a 5.43 gear in the Camaro w/ a 29.5x10.5 tire and a 1.76 glide. Just running 1/8 mile though.
I agree w/ the others and use a 4.88.
CHIP
'06 GMC 2500HD LBZ Duramax
