car won't 60 foot video
#2117591
07/25/16 09:04 PM
07/25/16 09:04 PM
birdtracker
https://www.youtube.com/watch?v=b2gEtOJ4Qdo472, powerglide, ladder bars,tryed a 5000 stall convertor and 5800. Tire pressure is 7psi. Tryed leavin at 3000, 4000, 4800 and 5000 with very little change. Once the car is in high gear its on. Looking for suggestions. Thanks. Birdtracker
Re: car won't 60 foot video
[Re: birdtracker]
#2117602
07/25/16 09:21 PM
07/25/16 09:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What shocks... it does seem very flat like the power isnt there.. whats your timing at
[Re: birdtracker]
#2117642
07/25/16 10:02 PM
07/25/16 10:02 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It just looks like the motor is numb at the hit. What are the 60' times anyway? ET & speed?
Timing, jetting, float level, cam size, low gear ratio, etc...... Could be any of those things or more.
[Re: birdtracker]
#2117904
07/26/16 03:28 AM
07/26/16 03:28 AM
Posts: 43,179 Bend,OR USA
Cab_Burge
Two things come to mind on this, is the shifter adjusted so it is in first only? The second thing is the reaction shaft is loose in the converter from the front pump. My car had that happen last year and again this weekend, I think The car lost a bunch of ET and MPH all of a sudden after stumbling on the line and looseing a bunch of 60 ft Let us know what you find, I've seen several cars leave like that when the shifter cable wasn't adjusted so the pin on the cable would slide in and out of the shifter arm in first gear, the shifter arm would move a little bit when you pulled the cable end pin out of the arm I've seen the same thing on torqueflytes, there leaving in two gears, not worth a hoot
[Re: birdtracker]
#2117960
07/26/16 10:31 AM
07/26/16 10:31 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
32" tire, powerglide...that thing needs a lot more gear than 4.10. We've run up to a 5.43 gear in the Camaro w/ a 29.5x10.5 tire and a 1.76 glide. Just running 1/8 mile though. I agree w/ the others and use a 4.88.
