Racers with G meters in there cars, how much G #2113506
07/19/16 07:48 PM
07/19/16 07:48 PM
Cab_Burge Offline OP
I am wondering what the actual the G forces are in a decent drag car running low 9 to high 8s, 1.20 to 1.30 60 ft times? help
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2113528
07/19/16 08:13 PM
07/19/16 08:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I typed my 60' which is 1.24 on Wallace calculator. Says I'm pulling 2.44 gs. My best et was 9.50. Don't know if it's accurate. Car does leave hard.
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2113625
07/19/16 10:06 PM
07/19/16 10:06 PM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
This is some data from my turbo car. Not the best 60' @ 1.387 on this pass.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2113631
07/19/16 10:11 PM
07/19/16 10:11 PM
Southington Ct.
Southington Ct.
This one from last year. Hit 2+G's on this one but had to lift because the car was heading on its roof. Ruined Mopar day at LVD after the shocks broke and oiled the track.....
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2114822
07/21/16 02:26 PM
07/21/16 02:26 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We've had our G meter to 3.3 but we run a little better than 8's.
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2114840
07/21/16 02:49 PM
07/21/16 02:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO there is no blanket answer for this question honestly. Depends on to many variables. Some cars hook hard and will show a fairly high spike in the G meter that will quickly fall off. Wheelies will affect it to some degree because it puts the logger at a sever angle momentarily. It is a great to compare runs but not sure there is a blanket answer. For instance with my throttle stop car it would hit 2G's then drop to nothing on the stop. It went bottom 8's or better off the stop and never saw more than 2.5. We have seen 3.2 in the NA 10.5 car, that was not one of our faster laps but one that stuck the tire hard and then pulled the engine down a bit.
I am sure Bob's car sees 3+ g's at 300' out as it freaking flies smile
Re: Racers with G meters in there cars, how much G [Re: Al_Alguire] #2114945
07/21/16 05:06 PM
07/21/16 05:06 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
My car is only 2.1 G's on a 1.154 60' running 8.0
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2114971
07/21/16 05:35 PM
07/21/16 05:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
As Monte pointed out, a launch is not a single progressive application of power through the tires, but a series of connected and related events where the chassis and tires recover and re-hook. The data logger shows more info of what went wrong, and I don't think all G meters respond quickly enough to pick up transients.
I agree, as Al says there is no blanket answer, only a trend, and best used to compare A & B in the same car, same day.
Boffin Emeritus
Re: Racers with G meters in there cars, how much G [Re: BobR] #2115008
07/21/16 06:30 PM
07/21/16 06:30 PM
Just a tiny bit better, correct whistling devilAre you talking about the current combination or the old one?
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2115082
07/21/16 08:47 PM
07/21/16 08:47 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Wallace says 2.29, sensor says 1.9, this was 9.07 et 1.28 60ft.
Re: Racers with G meters in there cars, how much G [Re: 540dust] #2115165
07/21/16 10:25 PM
07/21/16 10:25 PM
Your ET, MPH and 60 ft times are very close to my Cuda bow I had forgot how bad I could hurt my back in a car that 60 ft. well if I didn't push myself back into the seat before hitting the throttle to WOT realcrazy(I remembered real quiclky, it took around three passes realcrazy
I flew airplanes for 15 years and would occasionally put me and the airplane into a 1 to 2 g manuver, that was planned and took some time so I felt it come and go away, when you do a negative 1 to 2 G manuver for very long you can red out, which is not good tsk
Maybe some day I will be abe to step up to a data logger with a G meter and all the other good stuff luck
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2115340
07/22/16 08:16 AM
07/22/16 08:16 AM
gregsdart Online content
gregsdart  Online Content
Peak G force on a 1.282 60 ft going 8.90 was Max 2.24 in about .2 seconds, dropped to 1.56 Gs at about .4 seconds, and went back up to 2.07 at about .6 seconds after TB release. I gather it spun too much then hooked, pulling the motor down.
Re: Racers with G meters in there cars, how much G [Re: gregsdart] #2115540
07/22/16 02:54 PM
07/22/16 02:54 PM
I was hurting my back when I was throttle stopping the car to keep it over 10.00, I had the stop on in .03 and off 1.56 later, it was at around 1/4 throttle on the stop and WOT off the stop. I should have adjusted the stop to about 2/3 to 3/4 open on the stop so it wouldn't have hit me so bad when it came off and on the stop realcrazy
I may end up using the stop to run S/G and or maybe S/ST, the car weighs 2750 with me in it so it isn't a really good S/G car at that weight shruggy
Re: Racers with G meters in there cars, how much G [Re: Cab_Burge] #2115545
07/22/16 03:00 PM
07/22/16 03:00 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Old one. The current one is a transmission away from becoming track worthy. Due any day.
