Racers with G meters in there cars, how much G
#2113506
07/19/16 07:48 PM
07/19/16 07:48 PM
Posts: 43,202 Bend,OR USA
Cab_Burge
I am wondering what the actual the G forces are in a decent drag car running low 9 to high 8s, 1.20 to 1.30 60 ft times?
Re: Racers with G meters in there cars, how much G
[Re: Cab_Burge]
#2113528
07/19/16 08:13 PM
07/19/16 08:13 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
I typed my 60' which is 1.24 on Wallace calculator. Says I'm pulling 2.44 gs. My best et was 9.50. Don't know if it's accurate. Car does leave hard.
[Re: Cab_Burge]
#2113625
07/19/16 10:06 PM
07/19/16 10:06 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
This is some data from my turbo car. Not the best 60' @ 1.387 on this pass. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Cab_Burge]
#2113631
07/19/16 10:11 PM
07/19/16 10:11 PM
turbobitt
Southington Ct.
This one from last year. Hit 2+G's on this one but had to lift because the car was heading on its roof. Ruined Mopar day at LVD after the shocks broke and oiled the track.....
[Re: Cab_Burge]
#2114840
07/21/16 02:49 PM
07/21/16 02:49 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
IMO there is no blanket answer for this question honestly. Depends on to many variables. Some cars hook hard and will show a fairly high spike in the G meter that will quickly fall off. Wheelies will affect it to some degree because it puts the logger at a sever angle momentarily. It is a great to compare runs but not sure there is a blanket answer. For instance with my throttle stop car it would hit 2G's then drop to nothing on the stop. It went bottom 8's or better off the stop and never saw more than 2.5. We have seen 3.2 in the NA 10.5 car, that was not one of our faster laps but one that stuck the tire hard and then pulled the engine down a bit. I am sure Bob's car sees 3+ g's at 300' out as it freaking flies
[Re: Cab_Burge]
#2114971
07/21/16 05:35 PM
07/21/16 05:35 PM
Posts: 4,206 New York
polyspheric
New York
As Monte pointed out, a launch is not a single progressive application of power through the tires, but a series of connected and related events where the chassis and tires recover and re-hook. The data logger shows more info of what went wrong, and I don't think all G meters respond quickly enough to pick up transients. I agree, as Al says there is no blanket answer, only a trend, and best used to compare A & B in the same car, same day.
Boffin Emeritus
[Re: BobR]
#2115008
07/21/16 06:30 PM
07/21/16 06:30 PM
Cab_Burge
We've had our G meter to 3.3 but we run a little better than 8's. Just a tiny bit better, correct Are you talking about the current combination or the old one?
[Re: 540dust]
#2115165
07/21/16 10:25 PM
07/21/16 10:25 PM
Cab_Burge
Wallace says 2.29, sensor says 1.9, this was 9.07 et 1.28 60ft. Your ET, MPH and 60 ft times are very close to my Cuda I had forgot how bad I could hurt my back in a car that 60 ft. well if I didn't push myself back into the seat before hitting the throttle to WOT (I remembered real quiclky, it took around three passes I flew airplanes for 15 years and would occasionally put me and the airplane into a 1 to 2 g manuver, that was planned and took some time so I felt it come and go away, when you do a negative 1 to 2 G manuver for very long you can red out, which is not good Maybe some day I will be abe to step up to a data logger with a G meter and all the other good stuff
[Re: Cab_Burge]
#2115340
07/22/16 08:16 AM
07/22/16 08:16 AM
Posts: 10,008 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Peak G force on a 1.282 60 ft going 8.90 was Max 2.24 in about .2 seconds, dropped to 1.56 Gs at about .4 seconds, and went back up to 2.07 at about .6 seconds after TB release. I gather it spun too much then hooked, pulling the motor down.
[Re: Cab_Burge]
#2115545
07/22/16 03:00 PM
07/22/16 03:00 PM
Posts: 8,165 Left Coast
BobR
Left Coast
We've had our G meter to 3.3 but we run a little better than 8's. Just a tiny bit better, correct Are you talking about the current combination or the old one? Old one. The current one is a transmission away from becoming track worthy. Due any day.
