plug wires, top three or four brands? #2113297
07/19/16 02:20 PM
07/19/16 02:20 PM
gregsdart Offline OP
I saw Jegs plug wires , and at a 42$ price for 8.5 spiral core wires it sounds like a good deal. Also looking at other brands. I run alky and 15/1 compression, so I need something good. What say you?
Re: plug wires, top three or four brands? [Re: gregsdart] #2113301
07/19/16 02:24 PM
07/19/16 02:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run nothing but Taylor Spiro Pros.Last set on my 12.5 440 went like 15 years.Still worked great but looked crappy.Oh yeah even on BBs and SBs with headers no melted boots.My kid did run a part sleeve on 7 because his 62 300s headerers were 2 1/8 and close.His were on 6 years when he sold the car.Rocky
Chrysler Firepower
Re: plug wires, top three or four brands? [Re: gregsdart] #2113317
07/19/16 02:43 PM
07/19/16 02:43 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
X2 on the Taylors. I like the angled, molded boots seems they 'click' on better than some other brands and have the finger dimples to get them on and off with. No problem with spark at all.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: plug wires, top three or four brands? [Re: gregsdart] #2113319
07/19/16 02:49 PM
07/19/16 02:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Firecore then MSD..........If they're good enuff for Top Fuel, they're good enuff for anything..........
Re: plug wires, top three or four brands? [Re: RMCHRGR] #2113321
07/19/16 02:51 PM
07/19/16 02:51 PM
Kirkland, Washington
Pacnorthcuda Offline
x3 on the Taylors. Been running them for almost 30 years. I like the universal kit--the plug ends are molded on but you determine the length and attached the distributor end. Never a problem.
I also took the white "TAYLOR" writing off them with lacquer thinner (looks much better)
Re: plug wires, top three or four brands? [Re: RMCHRGR] #2113322
07/19/16 02:54 PM
07/19/16 02:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have used Taylor, MSD.. Firecore would be up
there also being they use them on TF engines that
run mags... I havent used the Firecore YET but I
was offered a set from Rich... but I havent measured
the lengths I need... I went with the big Taylors(I
think they were 12mm) but I didnt like the shielding
on them.. it seemed loose... my last 2 sets of wires
have been MSD 9.5mm(I think thats the size.. could be
10.5).. and I put wire looms on all my wires to keep
them separated plus it looks neater
wave
Re: plug wires, top three or four brands? [Re: gregsdart] #2113328
07/19/16 03:01 PM
07/19/16 03:01 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I use Magnecore$ 10mm on anything with turbos(heat) and electronics. Been tempted to try Firecores, but it's hard to turn away from something that I know works.
Have never had a failure with the Magnecores.
Re: plug wires, top three or four brands? [Re: gregsdart] #2113337
07/19/16 03:14 PM
07/19/16 03:14 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
We've been running moroso ultra 40 wires with the moroso sleeves on them for a while now and have never had a problem with them.
Re: plug wires, top three or four brands? [Re: gregsdart] #2113348
07/19/16 03:23 PM
07/19/16 03:23 PM
Renton Washington
Triple Threat Offline
Renton Washington
In no particular order
Firecore
MSD
Moroso Ultra 40
Taylor
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: plug wires, top three or four brands? [Re: gregsdart] #2113367
07/19/16 03:52 PM
07/19/16 03:52 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
MSD 8.5 with the multi angle plug boot.
We have also used the firecore wires.
Re: plug wires, top three or four brands? [Re: gregsdart] #2113376
07/19/16 04:07 PM
07/19/16 04:07 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Taylor wires on my small block. I don't like stuff flopping around.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: plug wires, top three or four brands? [Re: gregsdart] #2113392
07/19/16 04:31 PM
07/19/16 04:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Normally, I just use the MSD wires.
I just got some Accel 9000 for the ceramic plug boots, They seem OK, but don't fit the best with my setup. Maybe if they have a custom cut to fit kit where you can specify the ceramic end angles would be nice.
I haven't had good luck with the Taylor wires. Initially they work good, but the covering is pretty soft, and I have pulled the plug ends off some when changing plugs. My headers also seem to cook the taylors more than the MSD wires, but as mentioned earlier, I burnt the MSD plug boot also, so went to the ceramic ends. Too bad Jacobs went out of business, they made decent plug wires too.
Re: plug wires, top three or four brands? [Re: gregsdart] #2113628
07/19/16 10:09 PM
07/19/16 10:09 PM
Mo.
racerx Offline
racerx  Offline
Mo.
seems like I only get bout 2 years out of the MSD's, now I have the ultra 40's so far so good thumbs .
Re: plug wires, top three or four brands? [Re: gregsdart] #2113646
07/19/16 10:33 PM
07/19/16 10:33 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Firecore, then Moroso Ultra 40's
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: plug wires, top three or four brands? [Re: gregsdart] #2113680
07/19/16 11:17 PM
07/19/16 11:17 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Running ultra 40s as well,no complaints.
Re: plug wires, top three or four brands? [Re: moparborn] #2113738
07/20/16 12:37 AM
07/20/16 12:37 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
iagree
Re: plug wires, top three or four brands? [Re: gregsdart] #2113847
07/20/16 10:05 AM
07/20/16 10:05 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Ultra 40's and make them to fit - best wire out there in my mind
Re: plug wires, top three or four brands? [Re: gregsdart] #2113857
07/20/16 10:24 AM
07/20/16 10:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I bought some summit brand ones for my GM coil packs that I am using. I went cheap because I wasn't sure what I was going to do at first. The Summit brand ones look and feel just like Taylors and are the Taylor Blue color. I have been happy with them.
68 Barracuda Formula S 340
Re: plug wires, top three or four brands? [Re: gregsdart] #2113859
07/20/16 10:26 AM
07/20/16 10:26 AM
Those that are only getting two years out of a set of MSD wires, what goes wrong? Are they 8.5 mm or bigger?
Re: plug wires, top three or four brands? [Re: gregsdart] #2113873
07/20/16 10:39 AM
07/20/16 10:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've got 5 years or more on my MSD wires.. still
show good... now that I bought a new coil and moved
it over to almost the left fender the coil wire is
fairly long... I will see how long that last..its
about 18" and being its firing all the time it will
be the one to go first
wave
