Trick Flow 240 better than EZs? #2110782
07/15/16 08:49 PM
07/15/16 08:49 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Mancinis' has a pretty attractive deal on EZs with pushrods and valley + bolts. Are the OOTB TFs alot better?
I know the flow numbers on the new TFs between .400-500 look really respectable?
I've heard all the dings on Indy, what y'all think?
Re: Trick Flow 240 better than EZs? [Re: momopar] #2110854
07/15/16 10:25 PM
07/15/16 10:25 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i think the opportunities for future development would be with the Indy heads. Depends on what level of performance you're seeking.
Re: Trick Flow 240 better than EZs? [Re: rebel] #2111011
07/16/16 09:25 AM
07/16/16 09:25 AM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
But for a engine not going over 6500/6800 would the smaller runners be a better choice. I see the advantage of the 'max wedge' at big lift high RPM.
Those .400-.500 numbers on OOTB TFs look really good.
It has been years since considering new heads, but I seem to remember the price used to be a whole bunch more for the Indys.
Guess competition is a good thing for us?
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111068
07/16/16 11:50 AM
07/16/16 11:50 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
If i remember correctly i believe the TFs have better mid range numbers than the EZs. As Rebel pointed out the EZs have more room to grow.
I guess the question would be what kind of power are you looking to make? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111085
07/16/16 12:11 PM
07/16/16 12:11 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
580-600 would make me a happy camper.
I know I know, I will want more, but in my advanced years I have learned there is never going to be enough.
Kinda like years ago when we had a pretty nice boat, it made me real happy until seeing some of the 'better' boats at the ramp. The missus said sumthin that we always stick with me, "No matter what you have, someone will always have something better" Smart girl (wonder why she picked me?)
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111090
07/16/16 12:16 PM
07/16/16 12:16 PM
Roughbird72 Offline
Roughbird72  Offline
I would go with the TFs then, OOTB should get that.
I'd give them the once over & go.
Re: Trick Flow 240 better than EZs? [Re: Roughbird72] #2111247
07/16/16 06:08 PM
07/16/16 06:08 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
CNC Stealths or OOTB Trickflows will get you to 600 pretty easily.
If you want to take it up a notch from there, buy EZ's from Dwayne Porter and have him clean up the ports. A little more time and a little more effort but a little more power.
Re: Trick Flow 240 better than EZs? [Re: GY3] #2111455
07/16/16 11:57 PM
07/16/16 11:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My OOTB EZ's have me running 9.70's on pump gas....Right around 700hp...
We are running 7.12 in the 1/8th in a heavy car with a set of big valve stock cast iron Mopar heads...Pump gas. So 600 is possible with stock heads.
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111479
07/17/16 12:34 AM
07/17/16 12:34 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What would you be putting them on, and what additional work were you willing to consider doing to the heads before using them?
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111489
07/17/16 12:54 AM
07/17/16 12:54 AM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Just 'thinking out loud'.. I see these new Trickflows are pretty good for what they are. So I took a gander over at Mancinis' and saw the EZ price was right there with the TFs.
I know the EZs have been around for quite sometime, all the huplah over these new TFs just got me wondering y'know?
I looked at EZs many years back and the price sure has dropped.
Actually I'm putting together a shopping list and you know what cheapskates us guyz are.Just want to get it right the first time eh?
69 446 2295 pistons going e85 1050 Quickflow 254-260 @.050 Solid FT heavy B body 4.56, but will run 3.23 most of the time for just putzin' around.
Probably build a low deck 512 and keep my iron stuff for the numbers.
Shoot I really don't know, just came into some money so it's burnin' a hole in me pocket.
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111532
07/17/16 02:49 AM
07/17/16 02:49 AM
BradH Offline
BradH  Offline
You've just proposed two very different builds that would likely use different heads...
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111553
07/17/16 04:10 AM
07/17/16 04:10 AM
Buy the best set of heads you can now, even if you need to save some more money first and then reuse those heads on other builds later thumbs twocents I've never regretted doing that, I have regretted buying cheaper heads and then finding out they wouldn't make the power I wanted later down realcrazywork
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111659
07/17/16 11:22 AM
07/17/16 11:22 AM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Thanks Cab!
Damn, felt like I just got interrogated by the D.A.
YUP nothing is set in stone,,,,,,,,,,,,,,,yet. Just exploring and trying to get the best bang for me buck and be ready if the build changes/upgrades.
Sorry for blabbing, I feel like a kid with the old Sears 'Wishbook'!
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111668
07/17/16 11:41 AM
07/17/16 11:41 AM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Here's a question I can't seem to find. The consensus is the short valve in most BB mopar replacement heads really limits their output.
The Indy has .500 longer valves. Are the trick flows stock length?
I think I'm leaning towards the TFs as they seem to be all I need (and more)
Seems the makers are pretty good at listening to customer input too (although I've never heard a discouraging word about Indy(:
Re: Trick Flow 240 better than EZs? [Re: momopar] #2111718
07/17/16 12:51 PM
07/17/16 12:51 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
OK I found my answer, the new TFs do utilize a longer valve. (5.4")
The bigger 'Max Wedge' ports are basically for high RPM no?
I have read about keeping velocity up so that would give the nod to less port volume? (at lesser RPM/lift numbers)
Brad the only thing for sure on this build is I'm using e85 and shooting for big compression. The stroker is not a given at this time, but always the Boy Scout,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, wanna be prepared eh?
Re: Trick Flow 240 better than EZs? [Re: momopar] #2112004
07/17/16 07:46 PM
07/17/16 07:46 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
momopar ,
will the EZ in a max wedge port need offset rockers ? that may also be a consideration . I must say the Mancini pricing does open up the choices
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 240 better than EZs? [Re: momopar] #2112041
07/17/16 09:14 PM
07/17/16 09:14 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
I think they use regular offset rockers and headers etc. hence the handle 'EZ'? I have read the regular ones ARE Max Wedge, just as cast and not opened up? Rekon a steady hand and a good burr would net you some gains on the cheaper "as cast" ones?
I think I will just go with the TFs. I read about 30 pages on them and Andy has some pretty impressive numbers with not a whole bunch of cam. He was at 505 though, but a solid 600 out of 446 (for now) would make me one happy camper fo' sure!
Re: Trick Flow 240 better than EZs? [Re: momopar] #2112044
07/17/16 09:18 PM
07/17/16 09:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The motor Andy used for the testing in the TF thread is a 470, not a 505.
Does Mancini have the EZ's on sale somewhere? I looked on their site and the prices are the normal prices, same as they've been for several years.
Assembled std port heads for $1885, std port head "kit" for $2095.
Re: Trick Flow 240 better than EZs? [Re: momopar] #2112065
07/17/16 09:57 PM
07/17/16 09:57 PM
AndyF Online content
AndyF  Online Content
TF has dyno sheets showing more than 600 hp from a 440 with their heads, intake, hyd roller cam, etc. Seems fair to me although Mopar Muscle had trouble finding 600 hp.
My combo is a 470 inch low deck with 10.5 compression and a solid roller. Best pulls so far are in the 715 hp range but my engine isn't very "user friendly". It is more of a Pro Street type of engine than a daily driver.
Re: Trick Flow 240 better than EZs? [Re: momopar] #2112357
07/18/16 11:55 AM
07/18/16 11:55 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
We made 655 HP; 633 Ft Lb. at 5500 RPM on a 400/470 with the TF heads out of the box, solid cam 270 @ .050 &.640 lift; 10.25/1 on 91 octane. Makes for a great street/ strip build!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
