Re: Trick Flow 240 better than EZs?
[Re: momopar]
#2111068
07/16/16 11:50 AM
07/16/16 11:50 AM
Posts: 1,237 North Central, Indiana
Roughbird72
If i remember correctly i believe the TFs have better mid range numbers than the EZs. As Rebel pointed out the EZs have more room to grow. I guess the question would be what kind of power are you looking to make?
72 Plymouth Roadrunner 11.08@123.25
[Re: momopar]
#2111489
07/17/16 12:54 AM
07/17/16 12:54 AM
Posts: 407 NE Indiana
momopar
NE Indiana
Just 'thinking out loud'.. I see these new Trickflows are pretty good for what they are. So I took a gander over at Mancinis' and saw the EZ price was right there with the TFs.
I know the EZs have been around for quite sometime, all the huplah over these new TFs just got me wondering y'know?
I looked at EZs many years back and the price sure has dropped.
Actually I'm putting together a shopping list and you know what cheapskates us guyz are.Just want to get it right the first time eh?
69 446 2295 pistons going e85 1050 Quickflow 254-260 @.050 Solid FT heavy B body 4.56, but will run 3.23 most of the time for just putzin' around.
Probably build a low deck 512 and keep my iron stuff for the numbers.
Shoot I really don't know, just came into some money so it's burnin' a hole in me pocket.
[Re: momopar]
#2111659
07/17/16 11:22 AM
07/17/16 11:22 AM
momopar
NE Indiana
Thanks Cab!
Damn, felt like I just got interrogated by the D.A.
YUP nothing is set in stone,,,,,,,,,,,,,,,yet. Just exploring and trying to get the best bang for me buck and be ready if the build changes/upgrades.
Sorry for blabbing, I feel like a kid with the old Sears 'Wishbook'!
[Re: momopar]
#2111718
07/17/16 12:51 PM
07/17/16 12:51 PM
momopar
NE Indiana
OK I found my answer, the new TFs do utilize a longer valve. (5.4")
The bigger 'Max Wedge' ports are basically for high RPM no?
I have read about keeping velocity up so that would give the nod to less port volume? (at lesser RPM/lift numbers)
Brad the only thing for sure on this build is I'm using e85 and shooting for big compression. The stroker is not a given at this time, but always the Boy Scout,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, wanna be prepared eh?
[Re: momopar]
#2112004
07/17/16 07:46 PM
07/17/16 07:46 PM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
momopar , will the EZ in a max wedge port need offset rockers ? that may also be a consideration . I must say the Mancini pricing does open up the choices
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: momopar]
#2112044
07/17/16 09:18 PM
07/17/16 09:18 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The motor Andy used for the testing in the TF thread is a 470, not a 505.
Does Mancini have the EZ's on sale somewhere? I looked on their site and the prices are the normal prices, same as they've been for several years. Assembled std port heads for $1885, std port head "kit" for $2095.
[Re: momopar]
#2112357
07/18/16 11:55 AM
07/18/16 11:55 AM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
We made 655 HP; 633 Ft Lb. at 5500 RPM on a 400/470 with the TF heads out of the box, solid cam 270 @ .050 &.640 lift; 10.25/1 on 91 octane. Makes for a great street/ strip build!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
