Page 3 of 4 1 2 3 4
Re: Help me with 383 upgrade! [Re: 71383beep] #210637
02/16/09 12:34 PM
02/16/09 12:34 PM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
I will have the blocked decked. One concern now is the cam selection because I'm keeping the 3.23's for now, but will soon be switching to the 3.91's or even 3.73's.
Re: Help me with 383 upgrade! [Re: 71383beep] #210638
02/16/09 12:51 PM
02/16/09 12:51 PM
Detroit, USA.
MagnumGT Offline
MagnumGT  Offline
Detroit, USA.
I try to give actual examples rather than speculate. When I worked at a dyno shop in '03,
I saw one car that made a lot of HP out of a 383.
The guy had a '71 Charger since new, said he had tried four engine builders an gave up. Went out and bought the whole Edelbrock performer pack - assembled heads/solid cam/intake, all of it. Bolted this on his block that was at a true 10.0
compression. Made around 435 at the rear wheels...I was in shock because you can usually "hear" a stout engine before it get's strapped down and this one sounded mild - like the idle was up too high and the converter was too high of a stall. The customer was finally pleased and mostly because he did the work.
Re: Help me with 383 upgrade! [Re: ireland383] #210639
02/16/09 01:13 PM
02/16/09 01:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The term you need to use when speaking to your machist is Zero Deck the Pistons.. If you just tell him to deck the block he'll take a light pass to true the gasket surface, he needs to acurately know what your looking for...
As you already mentioned the camshaft selection is very important, I would suggest a Crower 271HDP it sfecs out with 222/234 duration .050 .486/.496 lift & 112 centers It's a good cam for a 383, I've got two friends running them & I plan to put one in my 383 next time I tear into it...
Re: Help me with 383 upgrade! [Re: 1_WILD_RT] #210640
02/16/09 03:08 PM
02/16/09 03:08 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
A note of caution. If your machinist is a chevy/ford guy make sure the head alignment dowels are removed BEFORE he ever touches the block. Had a local yokel cut the deck on a 400 this way. There is no way to positively locate the head and gasket if this happens. Glad to see you are keeping the 383
This space available for rent
Re: Help me with 383 upgrade! [Re: cptn60] #210641
02/16/09 10:11 PM
02/16/09 10:11 PM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
AS others have pointed out, don't go to big on the cam. When I rebuilt (re-ringed) my 383 a couple of years back, I put in the 509 because I wanted that prostock idle and I wanted to kill a little torque for the street (4spd, less wheel spin). It was fun romping around with that choppy idle but the power band dosn't kick in untill around 3000rpms.
My build is:
-.040 383 w/factory style flat tops & slighty decked. 9.10 calculated compression.
-516 heads, 2.14-1.81 valves, bowls ported and blended & straightened out exhaust ports. cced @ 72cc. Shim gaskets
-Holly SD w/800dp I know it's too big but all I had available and some old school Jardine headers.
The car has a 4spd and 3.91 gears so it makes the cam livable on the street. I'm either going to change the cam to a 528 solid or swap the gears to 4.30-4.56 for some extra zip in the street light grand prix.
Re: Help me with 383 upgrade! [Re: MrFoFody] #210642
02/17/09 02:48 AM
02/17/09 02:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We had a mild 383 in my sons Dart that ran very good. It was a stock shortblock that I rebuilt. I used the stock factory pistons and decked the block some. It was not bored as I honed the cylinder's and used .005 over rings with the stock pistons that I knurled and fit to the cylinders. The piston was still .030 down so I milled the 452 heads I used .060 and used the steel shim .019 head gasket to get 9.5 comp. All I did to the 452 heads was some mild bowl blending and added Comp single springs. I used the MP .484 cam on a 104 centerline with the stock rockers and pushrods but I had to shim the rocker shafts to get .020 lifter preload. We put the Eddy RPM intake on with a 750 DP and I used a stock electronic dist I recurved. Of course we used headers and a 727 with a manual valve body and a Turbo Action 10" tight 3000 converter. It had 3.91's and we used McCreay G60-15 tires with the stock leafsprings and air shocks. This was all in my sons 72 Dart that weighed right about 3600 with him in it. Never dynoed the car but it ran a best of 12.31 @ 110 and I guessed it made about 400 flywheel hp. It actually ran faster then I thought it would as I was just looking for high 12's with it. Here is a pic of his Dart that runs a .030 over 400 now. Ron
Re: Help me with 383 upgrade! [Re: 64Post] #210643
02/17/09 09:19 AM
02/17/09 09:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John, I'm not doubting Dwayne made the number, I just don't think it was as mild of a build as was let on.
My combo FWIW:
383 block .030+ By CRE
3.915 crank. 450 cid
12.3:1 static cr (10cc domes; .004/.005 below deck
MCH ported Eddys milled to 82 cc's-- we all know the numbers, plus I had them locally flowed. Jeff's numbers are a hair conservative.
Comp Custom solid cam= .261/.266 @ .050 .578/.585 gross lift
Eddy RPM intake
950HP worked by Biggs
1 3/4 Headers
HP? Unknown at this time. Might get it on the dyno in the spring...
I never said it was mild , it was built to be a LEGAL NHRA stock engine , built to blueprint spec with a stock lift cam . NHRA only calls out lift in the cam spec , you can get as wild on the cam duration as you please , he got a little long on the duration and had NEGATIVE piston to valve clearance .
I'm building a similar engine as you same compression smaller cam , except it will have 906's on it flow is unknown by me.
I'm told it'll be hard pressed to make 500hp with stock manifolds ...
Re: Help me with 383 upgrade! [Re: ireland383] #210644
02/17/09 09:24 AM
02/17/09 09:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
wait till you figure out what piston you THINK you want to run , if he gets you a piston that is .100 in the hole you DO NOT want to cut that off the deck .
I would consider dropping the extra coin and get a piston to fit a block that was just skimmed to get it back to square .
Re: Help me with 383 upgrade! [Re: 71383beep] #210645
02/17/09 09:32 AM
02/17/09 09:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree that they do not take much to get them going, but it seems that good compression is crucial in achieving it. Selecting cams and bolting on intakes and heads only works in fantasy land unless the motor had zero deck pistons to start with. My first builder just put in the pistons cleaned the deck and bolted on monstrous 906 open chambers...and gave me a motor that would not hold a tune to save its life.
It takes more than a zero deck piston to get compression in a stock stroke 383 , the small bore is the killer. Doing the math on factory built 383's you BARELY get 9.3 compression out of a CLAIMED 10.0 factory spec , the pistons have to be poking out of the deck .020 AND the heads cut down to 79.5 vs the as delivered 90-92 cc. or you have to stick a 10cc - 12 cc dome on the piston which gets in the way of proper flame travel .
I wish KB made a step head piston for the 383 like they do the 440 and 400 instead of that POS KB162 , that would go a LONG way toward helping the 383 builder .
Re: Help me with 383 upgrade! [Re: MrFoFody] #210646
02/17/09 09:34 AM
02/17/09 09:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My build is:
I'd swap in the .528 first .
sorry for all the posts , I was out of town over the weekend and had limited computer access ...
Re: Help me with 383 upgrade! [Re: JohnRR] #210647
02/17/09 09:43 AM
02/17/09 09:43 AM
Suffolk,VA
I
I
Suffolk,VA
That's is ok for all the posts more info helps. I should be getting a call from the builder today or Wednesday and will post what he finds when he opens the motor. Thanks
Re: Help me with 383 upgrade! [Re: cdp] #210648
02/17/09 09:50 AM
02/17/09 09:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So John, are you saying they didn't make the 450 like they claim in the Moparmuscle/Westech article? I was unaware of this if thats the case.
I need to see the original build of the engine and I need to know WHEN that engine was run at Westech . 450 is definitely possible , but I'm curious as to the compression ratio of that engine .
Re: Help me with 383 upgrade! [Re: JohnRR] #210649
02/17/09 09:58 AM
02/17/09 09:58 AM
Suffolk,VA
I
I
Suffolk,VA
Will the .528 cam affect the vacuum since I have power brakes,vacuum secondaries, and distributor?
Re: Help me with 383 upgrade! [Re: JohnRR] #210650
02/17/09 12:10 PM
02/17/09 12:10 PM
IL
71383beep Offline
71383beep  Offline
IL
With the second rebuild I paid very close attention to the #'s with the builder and he lamented that the piston choice was not the best. However, since they were in and in great shape he felt he could make them work. I don't have the numbers in front of me as to how much he took off the deck and how much he milled the heads, but I do know that him and I both took the time to make darn sure I was over 9:1 for compression. Consider it lessons learned...it seems like the manufacturers don't give a hoot about REAL 383's IMO.
How about the KB400's? What's your take on those? I've heard they are a better match for this issue, but have not had a chance to use them.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Help me with 383 upgrade! [Re: JohnRR] #210651
02/17/09 12:23 PM
02/17/09 12:23 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
John the compression was supposed to be 9.2:1. It was a September 2002 issue. I would have guessed the engine made 400-420 horse, they dynoed it at [Email]455@6000[/Email] rpm, which was the highest rpm tested. I thought the dyno doesn't lie I guess they must have done it but I've always been skeptical, it just seems a little to easy to make 450 horse with a 383 after reading the article. Maybe a happy dyno is the reason. Heres the article, let us know if the dyno was happy or not.
http://compcams.com/Community/Articles/Details.asp?ID=1111284973
Re: Help me with 383 upgrade! [Re: GTX MATT] #210652
02/17/09 01:05 PM
02/17/09 01:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The info about Westech being HAPPY came out in 2004 ( it came out after the we did the Enginemasters in 2003) , the numbers in that article ARE INFLATED .
Re: Help me with 383 upgrade! [Re: JohnRR] #210653
02/17/09 07:48 PM
02/17/09 07:48 PM
MO
cdp Offline
cdp  Offline
MO
So how over inflated did this article turn out to be? 40-50 horse?
Re: Help me with 383 upgrade! [Re: ireland383] #210654
02/17/09 08:42 PM
02/17/09 08:42 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm really curious as to his shop charges. All of those $50-$100 machining steps add up real quick, unless you short cut a few things. How much is he going to charge for the assembly?
Re: Help me with 383 upgrade! [Re: 64Post] #210655
02/17/09 09:42 PM
02/17/09 09:42 PM
Suffolk,VA
I
I
Suffolk,VA
I will have more details when I meet with him tomorrow or Thursday with a full break down of the build and cost. I forgot to add he has built plenty of Chrysler motors, not just Chevy and Fords.
Re: Help me with 383 upgrade! [Re: ireland383] #210656
02/17/09 10:44 PM
02/17/09 10:44 PM
Central NC
gch Offline
gch  Offline
Central NC
The .528 should have enough vacuum to run these accessories.At worst you could install a vacuum cannister but I don't think it will be needed.
Page 3 of 4 1 2 3 4
