Re: What air pressure for 14-32 radials
[Re: farmboy]
#2106194
07/08/16 12:38 PM
07/08/16 12:38 PM
Posts: 1,030 ohio
67mprfan
ohio
On my demon which weighs 3000 with me in it my Hoosier was around 8-9lbs
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2106200
07/08/16 12:43 PM
07/08/16 12:43 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
On my demon which weighs 3000 with me in it my Hoosier was around 8-9lbs Was they radials ?????? would not think so
[Re: VernMotor]
#2106204
07/08/16 12:48 PM
07/08/16 12:48 PM
Posts: 1,030 ohio
67mprfan
ohio
On my demon which weighs 3000 with me in it my Hoosier was around 8-9lbs Was they radials ?????? would not think so I'll have to check the are in my trailer now because I'm running Goodyear's 14-31 now
[Re: 67mprfan]
#2106250
07/08/16 02:15 PM
07/08/16 02:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On my demon which weighs 3000 with me in it my Hoosier was around 8-9lbs That sounds more like the pressure for a bias ply slick.. a radial will be higher... but like usual the car weight and traction will dictate pressure
[Re: MR_P_BODY]
#2106251
07/08/16 02:19 PM
07/08/16 02:19 PM
Posts: 4,672 Wichita
GY3
Wichita
I would set them at a minimum of 50 lbs. Especially when you're grudge racing against the '63 330...
[Re: farmboy]
#2106262
07/08/16 02:37 PM
07/08/16 02:37 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Generally those Radial slicks need to be in the 18-22lb range from my experience with the MT radial.
[Re: farmboy]
#2106319
07/08/16 05:10 PM
07/08/16 05:10 PM
Posts: 176 Sterling Heights, MI
John_T_Brown
I run M/T 14.5 x 33's on a 3500lb Super Stock with a 4-link and the pressure generally runs between 14.5 and 15 lbs to produce the best 60ft times.
If it ain't broke fix it anyway!
[Re: 408Dust]
#2106555
07/08/16 10:58 PM
07/08/16 10:58 PM
Posts: 391 kansas
farmboy
kansas
I don't use the M/T anymore, using Phoenix radial 13-14 on a usually hotter track here in the south. I had bad radial wobble with the M/T. Actually, that is the tire, I am running. Are you having good luck with it?
[Re: farmboy]
#2106705
07/09/16 08:33 AM
07/09/16 08:33 AM
Posts: 739 Florida
408Dust
I don't use the M/T anymore, using Phoenix radial 13-14 on a usually hotter track here in the south. I had bad radial wobble with the M/T. Actually, that is the tire, I am running. Are you having good luck with it? I have used them all, Phoenix is the only tire I use now.
[Re: farmboy]
#2106718
07/09/16 09:57 AM
07/09/16 09:57 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I tried the M/T radials in 15x33 when they first cam out, 3000 lb car, going 8.70s. Radial :wobble: was terrible, pressure had to be about 14 psi minimum but very little higher or no traction. Fastest passes the car ever made though, for the fuel and conditions. 60 fts were in the 1.27 range on the best day, biased slicks would go 1.24 but loose ET down track.
