What air pressure for 14-32 radials #2106181
07/08/16 12:08 PM
07/08/16 12:08 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I run about 16 lbs in my MT drag radials. Is that a good starting point for my 14-32 radial slicks. Automatic transmission, 3600 lbs.
Re: What air pressure for 14-32 radials [Re: farmboy] #2106194
07/08/16 12:38 PM
07/08/16 12:38 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
On my demon which weighs 3000 with me in it my Hoosier was around 8-9lbs
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: What air pressure for 14-32 radials [Re: 67mprfan] #2106200
07/08/16 12:43 PM
07/08/16 12:43 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Was they radials ?????? would not think so
Re: What air pressure for 14-32 radials [Re: VernMotor] #2106204
07/08/16 12:48 PM
07/08/16 12:48 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I'll have to check the are in my trailer now because I'm running Goodyear's 14-31 now
Re: What air pressure for 14-32 radials [Re: 67mprfan] #2106250
07/08/16 02:15 PM
07/08/16 02:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That sounds more like the pressure for a bias ply
slick.. a radial will be higher... but like usual
the car weight and traction will dictate pressure
wave
Re: What air pressure for 14-32 radials [Re: MR_P_BODY] #2106251
07/08/16 02:19 PM
07/08/16 02:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I would set them at a minimum of 50 lbs.
Especially when you're grudge racing against the '63 330... laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: What air pressure for 14-32 radials [Re: farmboy] #2106262
07/08/16 02:37 PM
07/08/16 02:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Generally those Radial slicks need to be in the 18-22lb range from my experience with the MT radial.
Re: What air pressure for 14-32 radials [Re: GY3] #2106286
07/08/16 03:47 PM
07/08/16 03:47 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Just don't sleep at the line, like last week.
Re: What air pressure for 14-32 radials [Re: farmboy] #2106319
07/08/16 05:10 PM
07/08/16 05:10 PM
Sterling Heights, MI
John_T_Brown Offline
I run M/T 14.5 x 33's on a 3500lb Super Stock with a 4-link and the pressure generally runs between 14.5 and 15 lbs to produce the best 60ft times.
If it ain't broke fix it anyway!
Re: What air pressure for 14-32 radials [Re: farmboy] #2106406
07/08/16 07:21 PM
07/08/16 07:21 PM
408Dust Offline
408Dust  Offline
I don't use the M/T anymore, using Phoenix radial 13-14 on a usually hotter track here in the south. I had bad radial wobble with the M/T.
Re: What air pressure for 14-32 radials [Re: 408Dust] #2106555
07/08/16 10:58 PM
07/08/16 10:58 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Actually, that is the tire, I am running. Are you having good luck with it?
Re: What air pressure for 14-32 radials [Re: farmboy] #2106613
07/09/16 12:43 AM
07/09/16 12:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run 16 to 18 in my 30 x 9 Hoosier radial slicks and it hooks fine all the time. Ron
Re: What air pressure for 14-32 radials [Re: farmboy] #2106660
07/09/16 01:54 AM
07/09/16 01:54 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
bawling
Re: What air pressure for 14-32 radials [Re: farmboy] #2106705
07/09/16 08:33 AM
07/09/16 08:33 AM
408Dust Offline
408Dust  Offline
I have used them all, Phoenix is the only tire I use now.
Re: What air pressure for 14-32 radials [Re: farmboy] #2106718
07/09/16 09:57 AM
07/09/16 09:57 AM
gregsdart Offline
gregsdart  Offline
I tried the M/T radials in 15x33 when they first cam out, 3000 lb car, going 8.70s. Radial :wobble: was terrible, pressure had to be about 14 psi minimum but very little higher or no traction. Fastest passes the car ever made though, for the fuel and conditions. 60 fts were in the 1.27 range on the best day, biased slicks would go 1.24 but loose ET down track.
Re: What air pressure for 14-32 radials [Re: farmboy] #2107110
07/10/16 01:21 AM
07/10/16 01:21 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Thanks for the help. Think I'll start around 17 and see how it feels.
Re: What air pressure for 14-32 radials [Re: farmboy] #2111517
07/17/16 02:01 AM
07/17/16 02:01 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I went with 17 lbs, and it hooked good enough to make me spend next week rebuilding the oil pan. Those tires work well.
