Re: My bracket hemi build
[Re: Triple Threat]
#2104237
07/05/16 02:14 PM
07/05/16 02:14 PM
Triple Threat
Renton Washington
I'll call this post a reliability update, been beating on this thing basically every weekend and haven't had any hiccups. Probably 75 runs on it now.
Ran a new best this weekend of 10.23@131, still 3500# of machine here. Really need to work on the 60 foot as that was only 1.46, It wants more gear and converter.
Made 17 runs on Saturday double entered into Pro and Footbrake (won Pro, R/U in Footbrake). Another 7 runs Sunday (won Pro). 24 passes in two days, on Saturday in the late rounds I made 5 runs in under an hour. Trans was smokin hot, but the engine just kept chugging along.
Everyone loves the hemi!
[Re: Triple Threat]
#2104302
07/05/16 04:11 PM
07/05/16 04:11 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Everyone loves the hemi! I am going to steal this quote for my newsletter, thank you, Dustin.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Triple Threat]
#2104463
07/05/16 08:47 PM
07/05/16 08:47 PM
Posts: 361 Canada
onig
Canada
Good job Dustin. That is a well put together engine. And congrats on those wins. Have you won enough money to pay for the build yet?
Onig
69 Dart
[Re: onig]
#2104861
07/06/16 12:40 PM
07/06/16 12:40 PM
Triple Threat
Renton Washington
Onig Thank you, only a bit over $4K winnings so far this year, still have a ways to go.
[Re: Triple Threat]
#2105442
07/07/16 02:59 AM
07/07/16 02:59 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I am real glad to hear that it is a happy motor! Keep up that check cashing
"Just a Bracket car dressed up like a streetcar"
[Re: Triple Threat]
#2105752
07/07/16 04:45 PM
07/07/16 04:45 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Everyone loves the hemi! you are THE MAN!!!!! bad ass
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Triple Threat]
#2105947
07/07/16 11:07 PM
07/07/16 11:07 PM
Posts: 57 cedar rapids, iowa
superhog88
cedar rapids, iowa
do you remember what deck height measured at on your block before machine work was done and are you running a stock timing chain
[Re: Triple Threat]
#2107898
07/11/16 02:26 PM
07/11/16 02:26 PM
Triple Threat
Renton Washington
8 More runs Saturday, New best ET of 10.21, 130.97mph 1.44 60'. 1100 Feet DA and 60% humidity, 29.59 Baro, 68 degrees.
Also got the win in Super Street (10.90 index)
[Re: STEFF]
#2112373
07/18/16 12:32 PM
07/18/16 12:32 PM
Triple Threat
Renton Washington
I'm betting you are shifting below your peak HP rpm. Have you tried taking it to 7400-7500? I think there is more in it but I haven't started leaning on it yet. With a 30" slick and only 4.10's the car definitely wants more gear and RPM. I'm possibly changing the gear later this fall, I'll test first with a 28" tire and see how it likes that. Only thing potentially holding it back up high would be the camshaft which is installed 5 degrees advanced at 103.
[Re: Triple Threat]
#2112476
07/18/16 02:45 PM
07/18/16 02:45 PM
Triple Threat
Renton Washington
It goes to 5800 on the brake and flashes similarly, it would probably like 6200+
[Re: Triple Threat]
#2115413
07/22/16 11:38 AM
07/22/16 11:38 AM
sixpackgut
Charleston
I'm betting you are shifting below your peak HP rpm. Have you tried taking it to 7400-7500? I think there is more in it but I haven't started leaning on it yet. With a 30" slick and only 4.10's the car definitely wants more gear and RPM. I'm possibly changing the gear later this fall, I'll test first with a 28" tire and see how it likes that. Only thing potentially holding it back up high would be the camshaft which is installed 5 degrees advanced at 103. Steff, he is going to turn it up after the 500 mile break in period
[Re: sixpackgut]
#2115433
07/22/16 12:29 PM
07/22/16 12:29 PM
Triple Threat
Renton Washington
Grandma owned, only driven to church on Sundays. Bracket racer problems... can't always change things if you want to win. What do you boys shift at? Ray? Steff? anyone?
