Re: Inner quarter panel coating
[Re: 1970RT]
#2105709
07/07/16 03:20 PM
07/07/16 03:20 PM
Posts: 601 Mass
charge70
Mass
RestoRicks is very good undercoating.Don't try to get it done in one coat, it will take a few coats to get the thickness and the texture correct.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2105738
07/07/16 04:25 PM
07/07/16 04:25 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
RestoRicks is very good undercoating.Don't try to get it done in one coat, it will take a few coats to get the thickness and the texture correct. This is correct. Most of today's undercoating goes on much thinner than the old/stock undercoating (but the old/stock may very well have contained asbestos... so we don't want that). Anyway, you can get weird imperfections if you spay on a modern undercoating too thick (drips, solvent pop, crazing, cratering, etc). The best way to "tie together" multiple coats of undercoating is to spray a coat, let it almost dry, re-coat & repeat until you get the thickness you want. That way you avoid most/all of the problems & the lower layer can partially mix with the upper layer. You also could completely remove the old/stock stuff first so that at least everything would look the same, if not original.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: charge70]
#2106704
07/09/16 08:21 AM
07/09/16 08:21 AM
Posts: 601 Mass
charge70
Mass
RestoRicks is very good undercoating.Don't try to get it done in one coat, it will take a few coats to get the thickness and the texture correct. I also found that using lower air pressure gave better looking results than higher pressure,a little lower than Ricks tech sheet recommended.
