What is the width of the top of E-body radiator support? #2103707
07/04/16 04:33 PM
07/04/16 04:33 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Hello,
I am in the process of repairing the radiator support of my '70 Challenger. As you can see, someone had some fun with a hole saw and an angle grinder back in the day. In addition to welding up each individual hole, I also need to add a bit of material on the lip of the support where they ground it off. I have taken a few pictures of what I am working with.
It looks like the outer edge is about 1.2 inches, and then it widens out a bit and narrows back down along the top of it. Can anyone verify my measurements?
Thanks!
Re: What is the width of the top of E-body radiator support? [Re: HemiStan] #2103709
07/04/16 04:35 PM
07/04/16 04:35 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
I started welding a few of them yesterday.
Stan
Re: What is the width of the top of E-body radiator support? [Re: HemiStan] #2103817
07/04/16 07:18 PM
07/04/16 07:18 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
These were taken at 6" from outside edge then 14" and 24".
Hope these help.Nice work by the way.
Re: What is the width of the top of E-body radiator support? [Re: HemiStan] #2103819
07/04/16 07:20 PM
07/04/16 07:20 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
This is the 6" pic.Sorry
Re: What is the width of the top of E-body radiator support? [Re: HemiStan] #2103985
07/04/16 11:28 PM
07/04/16 11:28 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
5carguy, Thanks! Those are perfect!
Stan
Re: What is the width of the top of E-body radiator support? [Re: HemiStan] #2104001
07/04/16 11:51 PM
07/04/16 11:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"someone had some fun with a hole saw."
Biggest understatement of the day, IMO grin
Re: What is the width of the top of E-body radiator support? [Re: HemiStan] #2104173
07/05/16 12:20 PM
07/05/16 12:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
As you can tell by the pictures of one that is not cut up the width across is not uniform , it's a part that is stamped from a flat sheet and the edge width can vary ...
Have fun filling those , another member had to go thru that in the rockers, under the sill plates , and other places on his 69 A12 Road Runner ...
