Stupid 'maintenance Required' light... 92 dodge ram
#2103311
07/03/16 11:17 PM
07/03/16 11:17 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Im selling my 92 D250. its got the 318 magnum. Its been an excellent truck, the only thing Ive ever had to do is replace a leaky rear wheel cylinder, clean the throttle body and IAC valve, and of course regular maintenance stuff (oil, filter, air cleaner).
Now, I dont know why, but it seems that when you sell a vehicle you all the sudden notice things that you never noticed before, even after years of owning the vehicle. The red 'maintenance req" light has been on ever since I bought the truck, and I pretty much forgot about it since Ive never had any issue with the truck besides the 2 I listed. I pretty much forgot it even existed and have been blind to it since owning the truck.
Now that Im selling it, its set off red flags with buyers. So I did some research and from what I can find this particular light was a regular scheduled maintenance reminder programed to turn on at certain intervals to remind the owner to take the truck back to the dealer for its scheduled maintenance, whatever it may be. After the dealership performed the maintenance, they turned the light off with their scan tool or whatever it was they used to talk to the ecm.
So, My truck is in great shape mechanically, and obviously the warranty is expired, so I cant just walk in and have them turn the light off for free.
Am I wrong about the purpose of the light?? To potential buyers, seeing this light on is basically like seeing a check engine light, but from everything Ive read, it is not the same at all. CAN SOMEONE CONFIRM WHAT THIS LIGHT IS AND TELL ME HOW THE HECK I TURN IT OFF!!?? If Im wrong, and it does indicate a certain problem(s), what are they??? This truck runs like its new
Re: Stupid 'maintenance Required' light... 92 dodge ram
[Re: Adam71Charger]
#2103318
07/03/16 11:34 PM
07/03/16 11:34 PM
Posts: 684 Maine
jerseybud
Maine
Used to be what you said: use a drb 1 tool and turn it off. Now, most dealers don't even have them now as they are antiquated. I'm not sure if a snap on 2500 will do it. It does not indicate a imminent or pressing issue
I'll be honest: I'd unplug the bulb since its not a quality of vehicle type thing. As long as check engine light still comes on at start up.
[Re: Adam71Charger]
#2103471
07/04/16 11:02 AM
07/04/16 11:02 AM
Posts: 1,357 central Florida
VL21
central Florida
IF I remember correctly, on my 92 Dakota 5.2, it was mileage related, I think every 50K and the purpose mainly was to remind you to clean/replace the EGR valve, I believe they were prone to clog.
I removed the bulb.
Actually, IIRC, it was a tiny bulb, and in the process of trying to remove it, broke it. Same result.
The truck went on after me to a friend, then to his nephew, and some over 300,000 miles, basically untouched.
This pic was from a Craigslist ad posted by a local yard, as it was taken to the yard ... and listed for parts, ironically one of the good parts listed was the engine ...
It takes gasoline to interest me.
[Re: Adam71Charger]
#2103536
07/04/16 12:32 PM
07/04/16 12:32 PM
Posts: 3,379 KY USA
mopargem
KY USA
I remember when mine came on with my 89 RAM. We were coming home from the Mopar Nats in Indy and that stupid light came on at 50k and I said [ Moparts Family Site - Keep it Friendly ] is wrong. After I got home I saw it was a reminder to replace the EGR or something like said.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: Adam71Charger]
#2103540
07/04/16 12:38 PM
07/04/16 12:38 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Some had a button you had to reset.Some had a battery.Depends on the vehicle.Look up a googl search.IIRC most were pretty easy to reset as they were for maintainve only.Supposed to have you return to dealer just for $$$.Rocky
Chrysler Firepower
[Re: Adam71Charger]
#2103749
07/04/16 05:38 PM
07/04/16 05:38 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm pretty sure that the scanners found in many modern shops will perform the same operations as the DRB II. Check a local independent shop.
[Re: Adam71Charger]
#2103915
07/04/16 09:50 PM
07/04/16 09:50 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Lite is for EGR kleening/maintance required by the EPA... Certain Chrysler cars actually had a small slide switch on the back of the cluster to reset the lite, close to the speedo.. Just my $0.02...
[Re: Adam71Charger]
#2103948
07/04/16 10:33 PM
07/04/16 10:33 PM
therocks
Niles , Ohio
There were like 2 or 3 different ways to reset the light.Some had a button you pushed and held some a battery some had a slide.It was for so called maintaince only.Like I said not hard to look it up on a Google search.Reset plenty back in the day.Rocky
Chrysler Firepower
[Re: therocks]
#2104604
07/06/16 12:46 AM
07/06/16 12:46 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Some had a button you had to reset.Some had a battery.Depends on the vehicle.Look up a googl search.IIRC most were pretty easy to reset as they were for maintainve only.Supposed to have you return to dealer just for $$$.Rocky This is right. Look it up as I dont remember what it took for that year off the top of my head. Some had a small box that you had to replace a 9 volt battery and then use a paper clip to push a reset button in the box. Some you just pushed a reset button and the later years you used the scanner to reset. It comes on for an emissions reminder to replace some emission parts. Some call for the EGR and the 02 sensors replacement. If you take it to a dealer they cant turn it out without doing the service so I would look up your year and model to see what it needs to turn it out. Ron
