LM2/Bosch sensor calibration #2101934
07/01/16 03:36 PM
07/01/16 03:36 PM
North Central, Indiana
Roughbird72 Offline OP
Just got my LM2(my first one) & the sensor will not completely heat for calibration. It gets to W99 & stays there. shruggy
I have double checked all connectors.
Has anyone else experienced this?
72 Plymouth Roadrunner 11.08@123.25
Re: LM2/Bosch sensor calibration [Re: Roughbird72] #2102040
07/01/16 06:18 PM
07/01/16 06:18 PM
Mark Whitener Offline
Have it swapped for a new one,
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: LM2/Bosch sensor calibration [Re: Roughbird72] #2102386
07/02/16 09:40 AM
07/02/16 09:40 AM
That's what i was afraid of.
Re: LM2/Bosch sensor calibration [Re: Roughbird72] #2102647
07/02/16 07:53 PM
07/02/16 07:53 PM
Brain fart! realcrazy got it.
Re: LM2/Bosch sensor calibration [Re: Roughbird72] #2103458
07/04/16 09:53 AM
07/04/16 09:53 AM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
I have a new LM2 that is doing the same thing. Channel 1 will not warm the sensor past w99. Channel 2 works fine. It is not a sensor problem because both sensors will work fine when plugged into Channel 2. We need to call Innovate directly about the problem. They have not responded to my e mails or request for return authorization. I'm completing some tuning using the channel that works then plan to send it back for repair. A little google searching indicates this may be a common issue.
1971 BS23H1B
Re: LM2/Bosch sensor calibration [Re: Roughbird72] #2103625
07/04/16 02:38 PM
07/04/16 02:38 PM
My "problem" was the default setting for the sensor which was 4.2 & mine came with the 4.9 ... something i just over looked.
Re: LM2/Bosch sensor calibration [Re: Roughbird72] #2103738
07/04/16 05:18 PM
07/04/16 05:18 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
OUCH! I recently purchased the LSU4.9 sensor and cable and it says in the manual that using the wrong setting may cause damage. That would have to be stated very clearly when shipping new units that may not be set up correctly. I think they owe you a solution.
Re: LM2/Bosch sensor calibration [Re: @#$%&*!] #2103766
07/04/16 05:57 PM
07/04/16 05:57 PM
Changed to the correct O2 sensor setting,calibrated it & it works fine.
like i said, brain fart.lol
