68 Charger RT Grille restoration #1982323
01/02/16 10:51 PM
01/02/16 10:51 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
I have a friend doing a numbers restoration on a 68 Charger RT and we need to find someone who does quality grille restorations. The unit is complete with a couple of broken fins.
thanks in advance
Re: 68 Charger RT Grille restoration [Re: scoutsr2] #1983189
01/04/16 12:41 AM
01/04/16 12:41 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Rod Glasser does them in Wichita. Plan on a grand if there is anything wrong. Its not cheap but it some of the nicest work I have seen. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 68 Charger RT Grille restoration [Re: astjp2] #2102222
07/01/16 11:41 PM
07/01/16 11:41 PM
Eastern, USA
Charger43 Offline
Charger43  Offline
Eastern, USA
Know the name of Rod Glassers shop? Address or phone #?
Re: 68 Charger RT Grille restoration [Re: scoutsr2] #2102291
07/02/16 01:04 AM
07/02/16 01:04 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Was'nt there someone in Missouri too?
68 Charger
70 Cuda
Re: 68 Charger RT Grille restoration [Re: scoutsr2] #2103035
07/03/16 02:12 PM
07/03/16 02:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just an fyi.
If u can get one done for under $1000 .....either
A - dont have high expectations. Or
B - Better jump on it.
Ive done maybe a half dozen of them.....and
1300 to 1500 range is not uncommon for a complete grille
Re: 68 Charger RT Grille restoration [Re: scoutsr2] #2105707
07/07/16 03:19 PM
07/07/16 03:19 PM
South Dakota
hotairballoonpilot Offline
South Dakota
mike at B/E &A did the 68 I did about 6 years ago. There was not much there and he made one out of a couple. Still holding up great!
corey
Contact Me about AMD Prices
Re: 68 Charger RT Grille restoration [Re: scoutsr2] #2105828
07/07/16 07:13 PM
07/07/16 07:13 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
I would guess I had 40 hours into each of my 69's I did.
It's tedious masking and a lot of the old plastic tabs are split and ears break off.
Also expect the body and grill NOT to mate up perfectly. You will assemble it on your table and then be baffled by it sitting twisted or cocked in The car.
I suspect this occurs because the cars are old, have some twist or fender replacement.
I had the us a die grinder on my Hemi car the get the Headlight Cover to drop properly.
Nonetheless,. Very rewarding when Complete
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
