track results on slicks..video added #2101742
07/01/16 11:15 AM
07/01/16 11:15 AM
an8sec70cuda Offline OP
Made 6 passes at the track this week on the new M/T 29.5x10.5 stiff sidewall slicks.
Started out w/ a 1.45 60', and ended up going a 1.34 sixty foot, 5.76 at 122 mph in the 1/8. The radials have been 1.30-1.31 and .08 quicker. MPH about the same.
Started w/ 13 psi in the tires, ended up at 15 psi. This big ole car moves around a LOT at 13 psi, lol.
Tightening the front rebound a lot and loosening the rear rebound on the shocks made it quicker. Tightening the front made the most difference.
Feels like the car is just punishing the tires through the 60'.
The good thing is that I went A to B every pass Wednesday night. That hasn't happened in a long time. The car barely pulls the front wheels off the ground now. Surprising and disappointing. Needs more tuning so hopefully it'll get better.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: track results on slicks [Re: an8sec70cuda] #2101757
07/01/16 11:29 AM
07/01/16 11:29 AM
gregsdart Offline
gregsdart  Offline
You may need more pressure yet? I run 9.75 psi in a 15 x 33 at 3000 lbs. Sounds like 17 or more might work? The clue was the fact that the car moved around at 13 psi. At 15 you are barely stable then, not enough to make them work right . I bet you will see a 1.30 or better on the next outing. up
Re: track results on slicks [Re: an8sec70cuda] #2101789
07/01/16 11:58 AM
07/01/16 11:58 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Needs more power down low now.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: track results on slicks [Re: an8sec70cuda] #2101801
07/01/16 12:13 PM
07/01/16 12:13 PM
Greg...very possible. After my first 3 passes and 2 air pressure changes, I knew the front was rising too fast...so I started w/ shock adjustments. I'll definitely be adding more air next time out.
Brad...I thought so too, so I brought everything in at the hit. Had been running a .2 delay. The car felt pretty good, but actually slowed down. Spun a little and slowed to a 1.37 60'.
That was my last pass of the night...until that pass, every pass kept getting faster. Just need more track time.
CHIP
Re: track results on slicks [Re: an8sec70cuda] #2101835
07/01/16 12:56 PM
07/01/16 12:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So those radials do works as many have proven but more pressure may help cos I was killin the tires at 12 lbs at a 1.33 so I too will go more pressure next time and hopefully we will both see quicker times...... thumbs
Re: track results on slicks [Re: an8sec70cuda] #2101848
07/01/16 01:23 PM
07/01/16 01:23 PM
Renton Washington
Triple Threat Offline
Renton Washington
At least you now have a solid base to test from, no fun blowing the tires off every run.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: track results on slicks [Re: an8sec70cuda] #2101849
07/01/16 01:23 PM
07/01/16 01:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Chip. Nice job.
Do you have tubes in them? That will give even more stiffness and stability to the sidewall.
I have never run more than 14 in a slick with my old car. But the more air you can get away with, the better.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: track results on slicks [Re: an8sec70cuda] #2101860
07/01/16 01:38 PM
07/01/16 01:38 PM
Dustin...EXACTLY!!! I was so frustrated after my last trip to the track, I was threatening Ray that I was going to put 32x14s under it, lol.
B3422W5...yessir, I have tubes in them. It still feels like it could use another pound or better. A friend got some video, but I'm not sure if he knows how to post them on youtube. Judging from the way the car felt, it's killing the tires.
CHIP
Re: track results on slicks [Re: an8sec70cuda] #2101864
07/01/16 01:47 PM
07/01/16 01:47 PM
K
KOS Offline
KOS  Offline
K
the car sounds like its more consistant than with the radials and this is only your first time out so keep at er probably get really close and even if you dont at least your not wasting your time spinning.... i havent even had a chance to try radials on my new car yet but im sure it will go quicker.
Re: track results on slicks [Re: an8sec70cuda] #2101926
07/01/16 03:19 PM
07/01/16 03:19 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The car is probably NOT moving around as much as you think. Cars on radials don't move. They track like they are on rails. Slicks move around, so if you are USED to running radials, when the car wanders a bit on slicks, your instinct is to correct it. Before long you are sawing the wheel and the car is back an forth. Try just holding the wheel straight, let back wander a bit and it will be fine. No way I would think that tire needs any more air on that car.
Have someone who KNOWS what they are looking at, to look at the tire tracks right after you leave. The marks will tell you exactly what you need to do for pressure
Re: track results on slicks [Re: Monte_Smith] #2104210
07/05/16 01:26 PM
07/05/16 01:26 PM
Monte...I didn't really have to "drive" the car. But you're right, it does FEEL like it's all over the place. It's more of a gentle sway all through 1st gear and into 2nd. After that it levels out.
I was hoping to get back out this week, but the temps are gonna be right around 100° the next couple days. Humidity will be up there too...not exactly good racing weather. I'll wait until we get some slightly cooler weather to try it again. Hopefully it'll come around w/ some shock adjustments.
If nothing else, I think the slicks look good on the car.
CHIP
Re: track results on slicks [Re: an8sec70cuda] #2104220
07/05/16 01:44 PM
07/05/16 01:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This pic is a 9.1x run with a 60 1.27-1.29 60ft about 1 car length out. I run 13.5 psi in my 10.5wx31@3350. To me this pic looks like it needs more air.
Doug
Re: track results on slicks [Re: an8sec70cuda] #2104334
07/05/16 05:18 PM
07/05/16 05:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
^^^^^^Why?
If it is because the tire is all wadded up.......that is because the car has too much bite.....NOT too little air in tires
Re: track results on slicks [Re: an8sec70cuda] #2104480
07/05/16 09:36 PM
07/05/16 09:36 PM
gregsdart Offline
gregsdart  Offline
Have you checked the accuracy of your pressure gauge? I had a name brand unit that was showing eight psi and only six psi true pressure. Yours may be fine, but it wouldn't hurt to check it against known gauges.
Re: track results on slicks [Re: an8sec70cuda] #2104498
07/05/16 09:54 PM
07/05/16 09:54 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
That's a heavy car, Chip. I wouldn't be surprised if you end up with close to 19-20 psi before you find the sweet spot. Running good! Can't wait until we line up side by side.
[image][/image]
Re: track results on slicks [Re: an8sec70cuda] #2104684
07/06/16 03:51 AM
07/06/16 03:51 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Hey Chip nice work - I agree mebbe 18-20 range might be the sweet spot. Keep us posted !
Re: track results on slicks [Re: an8sec70cuda] #2104693
07/06/16 04:30 AM
07/06/16 04:30 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No way...........not that much pressure in that tire. It isn't a radial. Its a bias ply slick
Re: track results on slicks [Re: an8sec70cuda] #2104697
07/06/16 04:39 AM
07/06/16 04:39 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Dang I got my wires crossed Monte wink
Thought they were radials, not bias.
Re: track results on slicks [Re: an8sec70cuda] #2104725
07/06/16 08:57 AM
07/06/16 08:57 AM
sgcuda Offline
sgcuda  Offline
Monte, I'm not saying that he needs 20. I'm saying that if 13 was causing the car to wander, and 15 felt more stable, 17 or 18 wouldn't be a bad idea at least to try and see if his 60 ft. comes around. 1 or 2 hits will let him know real fast.
[image][/image]
Re: track results on slicks [Re: sgcuda] #2104850
07/06/16 12:24 PM
07/06/16 12:24 PM
Got some video for yall to look at...
This was my 4th pass. https://www.youtube.com/watch?v=gQ1gkL5w48g
15 psi, .2 NOS delay footbraking.
1.40 sixty foot...lifted before the 330'
shocks were...
front 8 comp, 7 rebound
rear 14 comp, 4 rebound
0 being the loosest setting, 18 being stiffest.
This was my 5th pass. https://www.youtube.com/watch?v=pPldnbvAlpw
Best 60' of the night...15 psi, .2 NOS delay footbraking. I tightened up the rebound on the front shocks for this pass...went 1.34 sixty foot.
shocks were...
front 8 comp, 11 rebound
I know the video quality isn't great, but any suggestions?
CHIP
