AN fitting difference #2098490
06/26/16 01:44 PM
06/26/16 01:44 PM
Glendora Ca.
Just-a-dart Offline OP
Glendora Ca.
While changing a old -8 hose out yesterday I noticed the I.D. of a old fitting was small, so I took a minute to compare it to a few others I had.
I thought this was interesting.
"Just a Bracket car dressed up like a streetcar"
Re: AN fitting difference [Re: Just-a-dart] #2098497
06/26/16 01:56 PM
06/26/16 01:56 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Thanks for the info ! I'll be sure to keep this in mind .
Re: AN fitting difference [Re: Just-a-dart] #2098501
06/26/16 02:07 PM
06/26/16 02:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Why I recommend Aeroquip. XRP is a true aircraft cutter style end which some people don't like to work with, even though it is probably a better design and is more expensive. Summit? Who knows where that comes from. And the old Russell stuff was awful. No clue what the current stuff looks like. Earl's makes nice stuff and offers both styles, but I don't have any here to measure.
Interesting that I haven't been able to find any of these specs in anyone's information online.
Re: AN fitting difference [Re: CMcAllister] #2098662
06/26/16 06:08 PM
06/26/16 06:08 PM
Glendora Ca.
Glendora Ca.
I have been using Mostly XRP for years now.
Could someone measure the I.D. of other brands (Earls, Fragola, etc) just for reference?
Re: AN fitting difference [Re: Just-a-dart] #2098672
06/26/16 06:25 PM
06/26/16 06:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I think I have some 8AN Earls fittings in the shop.
Re: AN fitting difference [Re: Just-a-dart] #2098696
06/26/16 07:05 PM
06/26/16 07:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
XRP is top shelf. They just aren't available at the cut rate mail order giants. Probably a reason or 2 for that.
Re: AN fitting difference [Re: Just-a-dart] #2098712
06/26/16 07:24 PM
06/26/16 07:24 PM
I'm under the impression that 8AN should have a minimum I.D. of .500 through out the system, not smaller work
AN, Army Navy, standards are based on .0625 increments, 8 times .0625 equals .500 inch, correct? confused
Re: AN fitting difference [Re: Just-a-dart] #2098716
06/26/16 07:34 PM
06/26/16 07:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
My technical information says:
-8AN metal tubing outside OD - 1/2"
-8AN hose ID - .438"
-10AN hose ID - .562"
If you are referencing mil-spec or AN hardware - bolts, screws, etc. - then yes, -8 is 1/2", -6 is 3/8", etc.
Re: AN fitting difference [Re: Just-a-dart] #2098823
06/26/16 10:10 PM
06/26/16 10:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And here is what I got with three new unused fittings
.358 Summit
.367 Earls
.370 XRP
I have some Fragola stuff to as we just redid the Drasgter with all their stuff not long ago. Just cannot find an spare -8 fittings.
Re: AN fitting difference [Re: Just-a-dart] #2098920
06/27/16 12:01 AM
06/27/16 12:01 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
All of my Earls 8AN fittings are on a line, sorry.
Re: AN fitting difference [Re: Al_Alguire] #2099029
06/27/16 01:44 AM
06/27/16 01:44 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
.358 Summit
.367 Earls
.370 XRP
Is the Earls a cutter style?
Re: AN fitting difference [Re: justinp61] #2099031
06/27/16 01:47 AM
06/27/16 01:47 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I will have to check at home if I have any spare Australian made Speedflow fittings to see how they compare
Alan Jones
Re: AN fitting difference [Re: Just-a-dart] #2099083
06/27/16 04:32 AM
06/27/16 04:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes it is and Earls Swivel seal same type as the XRP..
Re: AN fitting difference [Re: Al_Alguire] #2103836
07/04/16 07:51 PM
07/04/16 07:51 PM
LA360 Offline
LA360  Offline
Aussie made Speedflow -8AN 0.389" ID
Alan Jones
Re: AN fitting difference [Re: LA360] #2104154
07/05/16 11:38 AM
07/05/16 11:38 AM
australia
charger410 Offline
charger410  Offline
australia
Speedflow are the best fitings I've used. Bigger internal sizes, more range, well suited to tighter spots. Here's a 45deg -8 earls and speedflow
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: AN fitting difference [Re: charger410] #2104175
07/05/16 12:21 PM
07/05/16 12:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is Speedflow just down under... those
do look like a nice fitting
wave
Re: AN fitting difference [Re: Just-a-dart] #2104377
07/05/16 06:27 PM
07/05/16 06:27 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: AN fitting difference [Re: VernMotor] #2104474
07/05/16 09:09 PM
07/05/16 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm starting to see that if you really want a
certain size on the American stuff you better
go up one more size... between the fitting it
screws onto and the fitting itself we choke ours
pretty good
wave
Re: AN fitting difference [Re: MR_P_BODY] #2104487
07/05/16 09:42 PM
07/05/16 09:42 PM
LA360 Offline
LA360  Offline
There is a dealer in California
http://www.speedflowusa.com/#
I hope that helps
Alan Jones
Re: AN fitting difference [Re: CMcAllister] #2104502
07/05/16 09:56 PM
07/05/16 09:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My Earls #8 measures .375-.377 id.............
