AN fitting difference
#2098490
06/26/16 01:44 PM
06/26/16 01:44 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
While changing a old -8 hose out yesterday I noticed the I.D. of a old fitting was small, so I took a minute to compare it to a few others I had.
I thought this was interesting.
"Just a Bracket car dressed up like a streetcar"
Re: AN fitting difference
[Re: Just-a-dart]
#2098501
06/26/16 02:07 PM
06/26/16 02:07 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Why I recommend Aeroquip. XRP is a true aircraft cutter style end which some people don't like to work with, even though it is probably a better design and is more expensive. Summit? Who knows where that comes from. And the old Russell stuff was awful. No clue what the current stuff looks like. Earl's makes nice stuff and offers both styles, but I don't have any here to measure.
Interesting that I haven't been able to find any of these specs in anyone's information online.
[Re: CMcAllister]
#2098662
06/26/16 06:08 PM
06/26/16 06:08 PM
Just-a-dart
Glendora Ca.
I have been using Mostly XRP for years now.
Could someone measure the I.D. of other brands (Earls, Fragola, etc) just for reference?
[Re: Just-a-dart]
#2098696
06/26/16 07:05 PM
06/26/16 07:05 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
XRP is top shelf. They just aren't available at the cut rate mail order giants. Probably a reason or 2 for that.
[Re: Just-a-dart]
#2098712
06/26/16 07:24 PM
06/26/16 07:24 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
I'm under the impression that 8AN should have a minimum I.D. of .500 through out the system, not smaller ![work work](/ubbthreads/images/graemlins/custom/work.gif) AN, Army Navy, standards are based on .0625 increments, 8 times .0625 equals .500 inch, correct? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: Just-a-dart]
#2098716
06/26/16 07:34 PM
06/26/16 07:34 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
My technical information says:
-8AN metal tubing outside OD - 1/2" -8AN hose ID - .438" -10AN hose ID - .562"
If you are referencing mil-spec or AN hardware - bolts, screws, etc. - then yes, -8 is 1/2", -6 is 3/8", etc.
[Re: Just-a-dart]
#2098823
06/26/16 10:10 PM
06/26/16 10:10 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
And here is what I got with three new unused fittings
.358 Summit .367 Earls .370 XRP
I have some Fragola stuff to as we just redid the Drasgter with all their stuff not long ago. Just cannot find an spare -8 fittings.
[Re: Al_Alguire]
#2099029
06/27/16 01:44 AM
06/27/16 01:44 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have some Fragola stuff to as we just redid the Drasgter with all their stuff not long ago. Just cannot find an spare -8 fittings. Is the Earls a cutter style?
[Re: Just-a-dart]
#2099083
06/27/16 04:32 AM
06/27/16 04:32 AM
Al_Alguire
Las Vegas
Yes it is and Earls Swivel seal same type as the XRP..
[Re: VernMotor]
#2104474
07/05/16 09:09 PM
07/05/16 09:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm starting to see that if you really want a certain size on the American stuff you better go up one more size... between the fitting it screws onto and the fitting itself we choke ours pretty good ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: CMcAllister]
#2104502
07/05/16 09:56 PM
07/05/16 09:56 PM
Thumperdart
State of confusion
My Earls #8 measures .375-.377 id.............
