69 road runner no spark #2097569
06/24/16 08:37 PM
06/24/16 08:37 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
jus got my 69 road runner back together from paint and rebuild.I have no spark in the sparkplug wires.I do have power in the points. I also have power in positve side of coil. i have power in the negative side of the the coil (not sure if thats normalL) i also have power in the single wire side of the ballast resistor. this is all when the key is turned on . Could it be a ground problem (new paint ) any help appreciated
Re: 69 road runner no spark [Re: 3wracing] #2097586
06/24/16 09:23 PM
06/24/16 09:23 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Put a testlight on the lowside of the coil. Crank engine. If it flashes, the points are working. Try a different coil.
Re: 69 road runner no spark [Re: Dean_Kuzluzski] #2097618
06/24/16 10:30 PM
06/24/16 10:30 PM
you have fire to the coil in "run". As you know you also need fire in "crank". pull the yellow wire off of the starter relay to disable the starter (you know it cranks & no need to run down the battery). Then have a helper hold the key to "start" & see if the coil primary positive terminal is hot. holler back
Re: 69 road runner no spark [Re: RapidRobert] #2097668
06/25/16 12:32 AM
06/25/16 12:32 AM
georgia
moparpro Offline
moparpro  Offline
georgia
double check your ground wire from distributor to coil.
Re: 69 road runner no spark [Re: 3wracing] #2097749
06/25/16 05:15 AM
06/25/16 05:15 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Dizzy rotor, cap and coil wire all ok? Had distributor been removed,,,,however even if improperly re-installed you would still have spark at wires when cranking, just not at correct time of course. If all ok, see Robert above,,,then likely connector at ignition switch or bulkhead or wiring to starter relay.
Re: 69 road runner no spark [Re: 3wracing] #2097830
06/25/16 12:19 PM
06/25/16 12:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check cap ,rotor and make sure dist is turning.As said test light to coil on dist side cranking should flash.Since you have power to pos side that says everything from there back is good.Ive also seen points not set correct and condensors and coil leads bad.Rocky
Chrysler Firepower
Re: 69 road runner no spark [Re: 3wracing] #2097836
06/25/16 12:29 PM
06/25/16 12:29 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I had the same problem with my Charger before I did the Pertronix. Ended up being a bad condenser
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 69 road runner no spark [Re: 69L78Nova] #2098278
06/26/16 02:16 AM
06/26/16 02:16 AM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
changed the ballast resistor and the condensor in the distributor starts and runs fine . thanks everyone
Re: 69 road runner no spark [Re: 3wracing] #2098281
06/26/16 02:23 AM
06/26/16 02:23 AM
if it would not start when cranking (ballast bypassed) then it'd be the condensor (kinda rare but does happen). Glad you got it taken care of
Re: 69 road runner no spark [Re: 3wracing] #2098447
06/26/16 12:40 PM
06/26/16 12:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Had a VW at work that had a bad condensor.Guy that supposedly was a VW expert took 1/2 the car apart trying to fix it.We told him like 5 times to change point and condensor as we had them in stock.Couldt be because they looked new.After about 30 hours they got changed.Was a miracle it started and ran great.Lots of times KISS works.Rocky
Chrysler Firepower
Re: 69 road runner no spark [Re: therocks] #2098491
06/26/16 01:47 PM
06/26/16 01:47 PM
Agreed, once in a tune up shop we worked on a vehicle that had been kicked out of three dealer shops & they couldn't get it & pretty much right away we saw that the dual point gap was way off, a call to the old Raceland speed shop to get the spec & easy fix.
