Re: 69 road runner no spark
[Re: 3wracing]
#2097586
06/24/16 09:23 PM
06/24/16 09:23 PM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
Put a testlight on the lowside of the coil. Crank engine. If it flashes, the points are working. Try a different coil.
[Re: Dean_Kuzluzski]
#2097618
06/24/16 10:30 PM
06/24/16 10:30 PM
RapidRobert
you have fire to the coil in "run". As you know you also need fire in "crank". pull the yellow wire off of the starter relay to disable the starter (you know it cranks & no need to run down the battery). Then have a helper hold the key to "start" & see if the coil primary positive terminal is hot. holler back
[Re: 3wracing]
#2097749
06/25/16 05:15 AM
06/25/16 05:15 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Dizzy rotor, cap and coil wire all ok? Had distributor been removed,,,,however even if improperly re-installed you would still have spark at wires when cranking, just not at correct time of course. If all ok, see Robert above,,,then likely connector at ignition switch or bulkhead or wiring to starter relay.
[Re: 3wracing]
#2097830
06/25/16 12:19 PM
06/25/16 12:19 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Check cap ,rotor and make sure dist is turning.As said test light to coil on dist side cranking should flash.Since you have power to pos side that says everything from there back is good.Ive also seen points not set correct and condensors and coil leads bad.Rocky
Chrysler Firepower
[Re: 3wracing]
#2097836
06/25/16 12:29 PM
06/25/16 12:29 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I had the same problem with my Charger before I did the Pertronix. Ended up being a bad condenser
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 3wracing]
#2098281
06/26/16 02:23 AM
06/26/16 02:23 AM
RapidRobert
if it would not start when cranking (ballast bypassed) then it'd be the condensor (kinda rare but does happen). Glad you got it taken care of
[Re: 3wracing]
#2098447
06/26/16 12:40 PM
06/26/16 12:40 PM
therocks
Niles , Ohio
Had a VW at work that had a bad condensor.Guy that supposedly was a VW expert took 1/2 the car apart trying to fix it.We told him like 5 times to change point and condensor as we had them in stock.Couldt be because they looked new.After about 30 hours they got changed.Was a miracle it started and ran great.Lots of times KISS works.Rocky
Chrysler Firepower
[Re: therocks]
#2098491
06/26/16 01:47 PM
06/26/16 01:47 PM
RapidRobert
Agreed, once in a tune up shop we worked on a vehicle that had been kicked out of three dealer shops & they couldn't get it & pretty much right away we saw that the dual point gap was way off, a call to the old Raceland speed shop to get the spec & easy fix.
