17" Steel rims that will fit a 74 Challenger #2097753
06/25/16 07:38 AM
06/25/16 07:38 AM
NY
K
Killerinc Offline OP
K
NY
Hey guys, Anyone know of 17" rims that will fit my 74 Challenger.
Looking for something cheap for now until i find a nice custom set.
thanks
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2097783
06/25/16 10:45 AM
06/25/16 10:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
There is nothing that fits exactly.
The newer Mopar wheels are not only the wrong offset, but the bolt pattern is slightly different. There are other models that have the 5 on 4.5 bolt pattern but the center register is smaller.
Some have used Mustang aluminum wheels but again, the offset is inboard more than you'd like.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2097816
06/25/16 12:03 PM
06/25/16 12:03 PM
Central NC
gch Offline
gch  Offline
Central NC
05 Chrysler 300/Dodge charger wheels will fit.I put four 17" steel wheels from one on my 75 Chrysler Newport with no problems.Offset is a little off but they bolt on and I had no problems with driving them.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2097824
06/25/16 12:13 PM
06/25/16 12:13 PM
Virginia
JimG Offline
JimG  Offline
Virginia
I took this photo at a cruise-in. I assumed they were Ford rims, but I never looked into it and never caught the owner at the car to ask.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2097898
06/25/16 02:20 PM
06/25/16 02:20 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
They look a lot like my brother's crown Vic pursuit wheels.
Re: 17" Steel rims that will fit a 74 Challenger [Re: gch] #2099085
06/27/16 04:44 AM
06/27/16 04:44 AM
NY
K
K
NY
So only the 2005 years will fit?
Re: 17" Steel rims that will fit a 74 Challenger [Re: gch] #2099091
06/27/16 05:06 AM
06/27/16 05:06 AM
NY
K
K
NY
Did a lil research and they say the wheels on the 300/Charger use a bolt circle of 115mm, whereas the older cars use 4.5" or 114.3".
People have chimed in a said that's really dangerous to do.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2099542
06/27/16 09:07 PM
06/27/16 09:07 PM
Central NC
gch Offline
gch  Offline
Central NC
It may be dangerous I am only telling you that it fit and the car drove just fine.Granted short trip or two only before I sold them to someone else.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2099673
06/27/16 11:43 PM
06/27/16 11:43 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
I own a set of rather old (10+ years) Stockton 17x8s and 17x10s. They use 15 inch Mopar centers welded into much larger hoops. I think that these wheels were the only aftermarket 17 inch steelies made with a true 5x4.5 bolt circle.
I was curious about this whole 115mm vs 114.3mm and found these two good topics on the subject on Ford forums - the second link is referenced in the first, and "The guy reported full conical seat contact, confirmed with paint marking."
http://forums.corral.net/forums/wheels-tires/1086950-dodge-charger-5-x-115mm-rims-mustang.html
http://vb.foureyedpride.com/showthread.p...20mopar%20wheel
So recent wheels on a 115mm circle are probably just fine, but older Mopar or CV Interceptor wheels on a true 5x4.5 bolt circle are objectively safest, even if there's only a 1/64" difference to each lug (per above topics).
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: 17" Steel rims that will fit a 74 Challenger [Re: JimG] #2100000
06/28/16 03:10 PM
06/28/16 03:10 PM
dogdays Offline
dogdays  Offline
Those are NOT Ford cop wheels. The 1998 - 2002 ford cop wheels have "D" shaped holes, and they only come in 16". They also have a slightly smaller center bore. I am using them myself. Later Ford cop wheels have a very high positive offset and don't look anything like those.
The steel wheels that ford used on the 1998 - 2002 cop cars were not cop specific. They also appeared on Rangers and Explorers. I would be inclined to say that the 17s on that car came from a ford product that had 17" wheels standard.
R.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2100952
06/30/16 02:57 AM
06/30/16 02:57 AM
NY
K
K
NY
I found this on Summit and its brand new and cheaper than junkyard's were selling used ones.
https://www.summitracing.com/parts/crr-83-7714/overview/
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2100956
06/30/16 03:34 AM
06/30/16 03:34 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I don't know B-bodies, so they may have more room than I think, but that has quite a bit of offset meaning it may be close to your tie rods, upper control arms, and leaf springs. What kind of tires were you planning on running?
Re: 17" Steel rims that will fit a 74 Challenger [Re: MuuMuu101] #2100960
06/30/16 04:59 AM
06/30/16 04:59 AM
NY
K
K
NY
If you look back at the first page, i think these are the same ones for 06 Charger's.
I'm just looking for a 17" steel rim.
Not sure about tires yet. I thought about 215/65 R17
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2101828
07/01/16 12:43 PM
07/01/16 12:43 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
When I ordered my wheels from Summit, I measured quite a bit. I even borrowed a friend's wheel and tire combo I thought was close to what I wanted and did some measurements. The good thing about your plan is that the tires you want are narrow (mine were 255's and will eventually go to 275's); however, a 215/65/17 is 28" tall. You're almost encroaching SUV tires. Are you going with that setup all the way around?
Another point to make, is that everyone's car is different. Factory tolerances were terrible. I found out when measuring my wheel and tire combo that my rear end was favoring one side about 0.25-0.5" more than the other. So, if you really want to know if they'll fit, measure up your wheel and see how much clearance you have, then compare it to what you want on this website and that should help you get a decent baseline to see if that wheel is practical.
http://rimsntires.com/specspro.jsp
Re: 17" Steel rims that will fit a 74 Challenger [Re: MuuMuu101] #2101984
07/01/16 04:43 PM
07/01/16 04:43 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Your point to measure is spot on.
I often ran 235-75-15 on B bodies, C bodies, and trucks. They fit fine. That tire is 28" X 7". Of course the back space was different and the wheels were usually 15" X 6" or 7"s wide.
I have 215-65-16 tires on one of my mini vans. They are 26" X 7"
The two vehicles ('78 pick-up & 07 mini van) side by side look so very different, but the tires are actually very close in size.
I also have a pair of 225 X 70 X 15 on stock aluminum C body wheels and they look big next to the mini van tires but are only an inch taller. Also 26" X 7"s but look tall and thin on 15" rims.
I think today's tires are simply a bit wider and it makes them seem shorter. A mini van is much shorter than a truck but the wheel well opening is very close in size. It makes 'em look different.
SUV or Mini Van. It's all very relative to perception.
If I recall the original post was for an early 70's B body. I would think you might want something in a 17" X at least an 8" wheel.
maybe some 245 or 255 series tires. I think that would be a bit wider than 7 or 8 inches and look much better. We used to put some big tires on those cars.
I don't like those rims linked @ summit for a muscle era car or truck. They look like a modern replacement wheel. Old stuff needs a different back space.
Myself I am in the market for a 17" rim to fit my 8 lug 3/4 ton pick up.
I have mechanical Aptitude.
I can screw up anything.
Re: 17" Steel rims that will fit a 74 Challenger [Re: Killerinc] #2134403
08/16/16 03:24 PM
08/16/16 03:24 PM
NY
K
K
NY
Got a question as per the Charger/Magnum wheels.
Can i use the ones with the TPMS sensor and without?
