Re: my 69 rr black, pewter int and pewter painted roof
[Re: Black 69 Beeper]
#2073714
05/15/16 08:03 AM
05/15/16 08:03 AM
Posts: 937 new jersey
Black 69 Beeper
new jersey
So I was back at it yesterday and put a little perspective on the alignment of the door. Luckily a friend had an extra original door that I could use to take measurements of. A little cutting , grinding, moving here and there and all the sheet metal with the exception of the hood is on and lined up for the final body work to start. Honestly if you have no clue what you are doing with panel replacement and body work I would stay away from the door skins that AMD sells unless you are prepared to pay a professional and its absolutely necessary to replace.
#2093902
06/18/16 11:58 AM
06/18/16 11:58 AM
Posts: 37 New Jersey
Vinny P
New Jersey
Loving the N96 hood Mike! I was happy to see it in person. Thanks for the tour of your shop. My baby is getting what it deserves. Keep in touch.
Vinny
Superbird B5 4 speed console black buckets
A12 Super Bee Bahama Yellow 4 speed black bench
#2096716
06/23/16 12:35 PM
06/23/16 12:35 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Thankfully yes. I am an auto body shop/ auto restoration teacher at a local vo-tec school. I have 2 down draft spray booths to my advantage. I did do under the hood, inside the car, and the trunk while it was in my home shop on the rotisserie. I'd make it work even if i didn't have the booths to use. they are there for me to use whenever so why not. Heck yes, I would be using it too.... Beautiful work....
#2126393
08/06/16 10:20 AM
08/06/16 10:20 AM
Black 69 Beeper
new jersey
Finished all the body work and my dad helped with the fitment of the rear window molding and test fitting of the rear window with the clips. Rear deck panels is finished as is the trunk jam.
