Page 23 of 32 1 2 21 22 23 24 25 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: new bee] #2037331
03/23/16 07:08 PM
03/23/16 07:08 PM
new jersey
Black 69 Beeper Offline OP
new jersey
thanks for the reminder.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2043386
04/01/16 11:14 AM
04/01/16 11:14 AM
new jersey
new jersey
If you guys are planning on re door skinning your doors using the AMD skins for a 68-69 Plymouth B-body, stay away from the passenger side one. The fit is god awful. I would have been better off fixing the door I had.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2073714
05/15/16 08:03 AM
05/15/16 08:03 AM
new jersey
new jersey
So I was back at it yesterday and put a little perspective on the alignment of the door. Luckily a friend had an extra original door that I could use to take measurements of. A little cutting , grinding, moving here and there and all the sheet metal with the exception of the hood is on and lined up for the final body work to start. Honestly if you have no clue what you are doing with panel replacement and body work I would stay away from the door skins that AMD sells unless you are prepared to pay a professional and its absolutely necessary to replace.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2086642
06/05/16 09:15 PM
06/05/16 09:15 PM
new jersey
new jersey
All body panels are hung, lined up, gaps cut ground and re welded if need be, and all looks like a 69 road runner. Now fun stuff starts.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2086643
06/05/16 09:17 PM
06/05/16 09:17 PM
new jersey
new jersey
few more shots. looking for an N.O.S. grill or a mint original if anyone has one please contact me copper1974@hotmail.com
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2087925
06/07/16 08:02 PM
06/07/16 08:02 PM
new jersey
new jersey
So the fenders have been removed. They have been scuffed inside and out. inside has been epoxy primed with PPG DP90LF black sealer and edged inside with black urethane.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2087992
06/07/16 10:10 PM
06/07/16 10:10 PM
CA, USA
JcodeCharger Offline
CA, USA
Nice!
68 twin turbo Dart 8.19 so far
70 Swinger 360
69 Roadrunner 383 4 speed
69 Mod Top Satellite 383 auto
69.5 A12 Super Bee 4 speed
70 T/A Challenger
70 FC7 Duster 340 4 speed
70 FJ5 Superbird
68 Hemi 4 speed Roadrunner
71 Duster W2 340
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2088796
06/09/16 12:58 AM
06/09/16 12:58 AM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
very nice!
1981 Dodge D150 360 auto
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2089595
06/10/16 12:23 PM
06/10/16 12:23 PM
new jersey
new jersey
Fenders are now painted on the inside, sealed on the outside with DP90LF epoxy primer sealer, and have 3 coats of PPG K36 urethane filler primer on the outside, and they have been edged in with DCC concept black urethane. They are now ready to be installed for the final time.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2089934
06/11/16 12:45 AM
06/11/16 12:45 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Looks like your fenders are in an awfully nice paint booth....
Re: my 69 rr black, pewter int and pewter painted roof [Re: minivan] #2090044
06/11/16 10:58 AM
06/11/16 10:58 AM
new jersey
new jersey
Thankfully yes. I am an auto body shop/ auto restoration teacher at a local vo-tec school. I have 2 down draft spray booths to my advantage. I did do under the hood, inside the car, and the trunk while it was in my home shop on the rotisserie. I'd make it work even if i didn't have the booths to use. they are there for me to use whenever so why not.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2093902
06/18/16 11:58 AM
06/18/16 11:58 AM
New Jersey
Vinny P Offline
Vinny P  Offline
New Jersey
Loving the N96 hood Mike! I was happy to see it in person. Thanks for the tour of your shop. My baby is getting what it deserves. Keep in touch.
Vinny
Superbird B5 4 speed console black buckets
A12 Super Bee Bahama Yellow 4 speed black bench
Re: my 69 rr black, pewter int and pewter painted roof [Re: Vinny P] #2096672
06/23/16 11:22 AM
06/23/16 11:22 AM
new jersey
new jersey
Te hood is pretty much ready to be finish wet sanded. It will be sealed and painted with the car. The trunk lid has been stripped to bare metal, there was a small section on the under edge that needed to be fabricated and welded, its been epoxy sealed, seam sealed, sealed again, and edged in in black. The body work will be finished on the car.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2096716
06/23/16 12:35 PM
06/23/16 12:35 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Heck yes, I would be using it too.... Beautiful work....
Re: my 69 rr black, pewter int and pewter painted roof [Re: minivan] #2107214
07/10/16 11:03 AM
07/10/16 11:03 AM
new jersey
new jersey
So I have mentioned that I have become a BIG fan of urethane spray-able truck bed liner. Heres the inside front inner wheels. It looks clean, replicates the factory undercoating, is a sound deaden-er, is durable, and is easy to maintain. These are the areas prepped.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2107215
07/10/16 11:05 AM
07/10/16 11:05 AM
new jersey
new jersey
Here's the finished product. The car is going to be driven and drag raced and I want easy of maintenance.
inner wheelwell finished pass.JPGinner wheelwell finished pass 2.JPGinner wheelwell finished dr.JPG
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2108865
07/12/16 06:12 PM
07/12/16 06:12 PM
new jersey
new jersey
Body work, Body work!it may not seem like much but the car is black. the back window is complete, all the moldings are fit, the rear shelf panel is finished, and the roof is ready for sealer and filler primer.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2108866
07/12/16 06:13 PM
07/12/16 06:13 PM
new jersey
new jersey
Trunk seams are finished also and the trunk jam is ready to be sealed, filler primed, wet sanded, and trimmed out in black.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2126390
08/06/16 10:14 AM
08/06/16 10:14 AM
new jersey
new jersey
Something as simple as inner fender plastic liners. People not involved in this hobby don't realize how much time it takes to do this kind of stuff.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2126393
08/06/16 10:20 AM
08/06/16 10:20 AM
new jersey
new jersey
Finished all the body work and my dad helped with the fitment of the rear window molding and test fitting of the rear window with the clips. Rear deck panels is finished as is the trunk jam.
