Re: A Question for transmission techs or those who service them
[Re: Badge]
#2095139
06/20/16 06:16 PM
06/20/16 06:16 PM
RapidRobert
look at the (3) holes in the filter (their offset pattern) & there are the same holes/same pattern in the VB & just orient/turn the filter till they line up & the oil suction hole location will also match the one in the VB
[Re: Badge]
#2095219
06/20/16 08:37 PM
06/20/16 08:37 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Filter holes location. If a true bozo assembled the trans there might be screws in these holes.
[Re: moparx]
#2095611
06/21/16 01:20 PM
06/21/16 01:20 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
Filter holes location. If a true bozo assembled the trans there might be screws in these holes. and if this is the case, what other surprises lurk inside ? No kidding , I took the pan off a friends 904 once and to my surprise ... NO FILTER ... It was last worked on my a trans shop ...
