Eagle running with Holley HP EFI #2094708
06/20/16 12:14 AM
06/20/16 12:14 AM
ghinmi Offline OP
ghinmi  Offline OP
Finally got mine up and running. It's a 5.7 Eagle with the vvt locked out running on the cheaper Holley HP EFI. I used a cable throttle body so that I didn't need the Dominator EFI to save money.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2094764
06/20/16 01:29 AM
06/20/16 01:29 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What's all that turboey looking stuff on the passenger side? Mind to share the whole build, looks BA!
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2094805
06/20/16 03:22 AM
06/20/16 03:22 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That will be fun!
Mopar to the bone!!!
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2094829
06/20/16 09:03 AM
06/20/16 09:03 AM
State College, Pennsylvania
fatman Offline
fatman  Offline
Thanks, keep us updated !
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2094847
06/20/16 10:03 AM
06/20/16 10:03 AM
USA
hudsonhornet7x Offline
USA
Looks and sounds great! What did you do to lock out the VVT?
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2094867
06/20/16 11:01 AM
06/20/16 11:01 AM
ghinmi Offline OP
ghinmi  Offline OP
Thanks guys! It's basically a stock 5.7 and 6 speed from a 2010 Challenger with a baby s366 billet wheel turbo. I was going to have to build headers for the swap anyways so I figured I might as well do the turbo now so that I have room to grow without reworking everything down the road. Here' the super long and drawn out version of the build. http://ifsja.org/forums/vb/showthread.php?t=127321
Re: Eagle running with Holley HP EFI [Re: hudsonhornet7x] #2094868
06/20/16 11:07 AM
06/20/16 11:07 AM
ghinmi Offline OP
ghinmi  Offline OP
I used the Comp Cams lockout kit and gutted the phaser. The issue with that is you can't degree the cam with the stock timing set. So I made an adjustable timing set by broaching new keyways in the bottom gear and degreed the cam correctly. Simple and easy.
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2112743
07/18/16 08:48 PM
07/18/16 08:48 PM
ghinmi Offline OP
ghinmi  Offline OP
Been driving it all over the place. Makes boost so easy. Quick video of driving thru town. I get on it once about 4:55 in.
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2112760
07/18/16 09:01 PM
07/18/16 09:01 PM
USA
USA
PM sent
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2183224
10/26/16 08:17 PM
10/26/16 08:17 PM
fatman Offline
fatman  Offline
I'd love to know the specs of your reground cam, if you don't mind. -scott
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2183238
10/26/16 08:34 PM
10/26/16 08:34 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Where did you install the cam at and what are your cam specs?
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2183462
10/27/16 12:18 AM
10/27/16 12:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I didn't know you had the Hemi Cherokee from Drag Week, awesome unique build that runs damn good!
68 Barracuda Formula S 340
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2183564
10/27/16 02:54 AM
10/27/16 02:54 AM
ghinmi Offline OP
ghinmi  Offline OP
The cam is locked out and installed at 107-ish. Went a little advanced for low end, the turbo can make it rpm. The deal didn't work out on a reground cam with a certain vendor. I'll never in my life pay $750+ for an aftermarket cam. A billet roller cam for my AMC was less than half that. I can make my own blank and have it ground for less if I wanted to.
And yeah, drag week was a blast! The Jeep was pretty much flawless all week, averaged 16.5 mpg driving like a crazy person. Literally just put fuel in it and changed tires. It's been a best of 11.46 @ 120.2 now on only 6 psi.
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2228588
01/06/17 01:58 PM
01/06/17 01:58 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
nice.....i want to see more, is this the one on a c10 frame?
Re: Eagle running with Holley HP EFI [Re: ghinmi] #2228649
01/06/17 03:23 PM
01/06/17 03:23 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
F-ing cool, I had a 78 I always wanted to drop on to a D100/150 frame, never got to it,
Nice job,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
