Finally got mine up and running. It's a 5.7 Eagle with the vvt locked out running on the cheaper Holley HP EFI. I used a cable throttle body so that I didn't need the Dominator EFI to save money.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
Re: Eagle running with Holley HP EFI
[Re: ghinmi]
#2094764 06/20/1601:29 AM06/20/1601:29 AM
Thanks guys! It's basically a stock 5.7 and 6 speed from a 2010 Challenger with a baby s366 billet wheel turbo. I was going to have to build headers for the swap anyways so I figured I might as well do the turbo now so that I have room to grow without reworking everything down the road. Here' the super long and drawn out version of the build. http://ifsja.org/forums/vb/showthread.php?t=127321
Looks and sounds great! What did you do to lock out the VVT?
I used the Comp Cams lockout kit and gutted the phaser. The issue with that is you can't degree the cam with the stock timing set. So I made an adjustable timing set by broaching new keyways in the bottom gear and degreed the cam correctly. Simple and easy.
[Re: ghinmi]
#2112743 07/18/1608:48 PM07/18/1608:48 PM
Where did you install the cam at and what are your cam specs?
[Re: ghinmi]
#2183462 10/27/1612:18 AM10/27/1612:18 AM
The cam is locked out and installed at 107-ish. Went a little advanced for low end, the turbo can make it rpm. The deal didn't work out on a reground cam with a certain vendor. I'll never in my life pay $750+ for an aftermarket cam. A billet roller cam for my AMC was less than half that. I can make my own blank and have it ground for less if I wanted to.
And yeah, drag week was a blast! The Jeep was pretty much flawless all week, averaged 16.5 mpg driving like a crazy person. Literally just put fuel in it and changed tires. It's been a best of 11.46 @ 120.2 now on only 6 psi.
[Re: ghinmi]
#2228588 01/06/1701:58 PM01/06/1701:58 PM
