Re: 604 in limp in mode
[Re: Paul_Fancsali]
#2094602
06/19/16 09:00 PM
06/19/16 09:00 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
NEED: Year Make Model Engine size
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Paul_Fancsali]
#2094717
06/20/16 12:25 AM
06/20/16 12:25 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Check eng lite on should just say in PCM a trans code is set. You need to read the TCM codes. Depending on the year as to where you hook to read the TCM the 95 and earlier will have a trans/body connector inside the vehicle as its a kinda square connector. 96 and newer used the OBDII connector under the dash for the PCM and TCM. Ron
[Re: Paul_Fancsali]
#2095233
06/20/16 09:18 PM
06/20/16 09:18 PM
Dartsport540
Ringtown, Pa.
Info is from Direct Hit. Chrysler service manuals. PO604 Internal TCM Malfunction..
P0604 Internal TCM Malfunction (Automatic Transmission)
Using the schematics as a guide, inspect the wiring and connectors. Repair as necessary. Pay particular attention to all power and ground circuits. If there are no possible causes remaining, view repair. All Repair Replace the Powertrain Control Module. WITH THE DRBIIIt PERFORM QUICK LEARN AND REPROGRAM PINION FACTOR. Perform 41TE (NGC) TRANSMISSION VERIFICATION TEST VER 1.
P0604 Internal TCM Malfunction - Automatic Transmission
Possible Causes Setting Conditions • PCM needs to be replaced, and then reprogrammed Key on; and the PCM detected an internal problem in the TCM during the Self-Test.
[Re: 383man]
#2095480
06/21/16 08:13 AM
06/21/16 08:13 AM
Dartsport540
Ringtown, Pa.
Did I miss that ? I just dont see where he said it had code P0604 ? Ron What is the title of this post?? Paul
[Re: Dartsport540]
#2095582
06/21/16 12:12 PM
06/21/16 12:12 PM
Posts: 19,476 north of coder
moparx
Did I miss that ? I just dont see where he said it had code P0604 ? Ron What is the title of this post?? Paul the trans axle is a model 604/41TE.
[Re: Paul_Fancsali]
#2095734
06/21/16 04:35 PM
06/21/16 04:35 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Isn't that the transmission with the solenoid packs mounted up front? Lots of those things got a full rebuild when all they needed were wiring repairs or solenoid packs.
Some of those problems would not kick a code because the way they failed did not present as a problem to the TCM.
[Re: moparx]
#2095746
06/21/16 05:00 PM
06/21/16 05:00 PM
Dartsport540
Ringtown, Pa.
Did I miss that ? I just dont see where he said it had code P0604 ? Ron What is the title of this post?? Paul the trans axle is a model 604/41TE. My mistake. I replied for a trouble code"PO604"
