604 in limp in mode #2094245
06/19/16 12:50 AM
06/19/16 12:50 AM
P
Paul_Fancsali Offline OP
P
My trans pulled this stunt last night My code reader won't read it and the check engine light is illuminated. I assume speedo sensors or solenoid pack. The reader I have should scan and read it but it indicates it is OK ?? I will not disconnect battery until I get a snap code reader on it any suggestions?
Re: 604 in limp in mode [Re: Paul_Fancsali] #2094602
06/19/16 09:00 PM
06/19/16 09:00 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
NEED: Year
Make
Model
Engine size
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 604 in limp in mode [Re: Paul_Fancsali] #2094717
06/20/16 12:25 AM
06/20/16 12:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Check eng lite on should just say in PCM a trans code is set. You need to read the TCM codes. Depending on the year as to where you hook to read the TCM the 95 and earlier will have a trans/body connector inside the vehicle as its a kinda square connector. 96 and newer used the OBDII connector under the dash for the PCM and TCM. Ron
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095113
06/20/16 05:28 PM
06/20/16 05:28 PM
P
P
Year 2003 Caravan
3.3 engine non flex
I just had a Snap on analyzer on it at shop and like mine it cannot make connection to trans computer?? Connections fuses all seem in order 96K and fluid is clean car has just limp in and reverse Looking for any suggestions to start
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095157
06/20/16 06:48 PM
06/20/16 06:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ok,now disconnect the battery and see if the trans resets itself. Some times it's just a hiccup in the operation and not a real issue.
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095161
06/20/16 07:02 PM
06/20/16 07:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would get the trans codes read first because if the ck eng lite is on it should have a code in it. Any Mopar dealer can read both the PCM and TCM codes for you. Why clear it before you find out what it is ? Once you have the trans code read then clear it and if it comes back you will know if its the same code. That will tell you the TCM set the same code twice and give you a good idea the problem is in the circuit that the code was set for. Ron
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095233
06/20/16 09:18 PM
06/20/16 09:18 PM
Ringtown, Pa.
Ringtown, Pa.
Info is from Direct Hit. Chrysler service manuals.
PO604 Internal TCM Malfunction..
P0604 Internal TCM Malfunction (Automatic Transmission)
Using the schematics as a guide, inspect the wiring and connectors. Repair as necessary. Pay particular attention to all power and ground circuits. If there are no possible causes remaining, view repair.
All
Repair
Replace the Powertrain Control Module. WITH THE DRBIIIt PERFORM QUICK LEARN AND REPROGRAM PINION FACTOR. Perform 41TE (NGC) TRANSMISSION VERIFICATION TEST VER 1.
P0604 Internal TCM Malfunction - Automatic Transmission
Possible Causes Setting Conditions
• PCM needs to be replaced, and then reprogrammed
Key on; and the PCM detected an internal problem in the TCM during the Self-Test.
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095420
06/21/16 01:29 AM
06/21/16 01:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Did I miss that ? I just dont see where he said it had code P0604 ? Ron
Re: 604 in limp in mode [Re: 383man] #2095480
06/21/16 08:13 AM
06/21/16 08:13 AM
Ringtown, Pa.
Ringtown, Pa.
What is the title of this post?? Paul
Re: 604 in limp in mode [Re: Dartsport540] #2095582
06/21/16 12:12 PM
06/21/16 12:12 PM
moparx Offline
moparx  Offline
the trans axle is a model 604/41TE.
beer
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095734
06/21/16 04:35 PM
06/21/16 04:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Isn't that the transmission with the solenoid packs mounted up front?
Lots of those things got a full rebuild when all they needed were wiring repairs or solenoid packs.
Some of those problems would not kick a code because the way they failed did not present as a problem to the TCM.
- Stu Harmon
Re: 604 in limp in mode [Re: moparx] #2095746
06/21/16 05:00 PM
06/21/16 05:00 PM
Ringtown, Pa.
Ringtown, Pa.
beer
My mistake. I replied for a trouble code"PO604"
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095750
06/21/16 05:10 PM
06/21/16 05:10 PM
P
P
Currently checking wiring and harness nothing yet.The best part for me is Dodge wants me to buy another extended warranty on my Journey already covered by limited lifetime on engine and driveline It is only hair under $3,000 + tax The same geniuses turned me away after I returned the Journey for issue with the second recall WIN that will fail at times to start. Never did it before the dealer touched it. So I'm hurrying to buy another warranty after they tell me $98 and hour to diagnosis a recall item. Oh well
PS Thanks for all the reply's You guy's do go out of your way!
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095799
06/21/16 06:36 PM
06/21/16 06:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You should be able to get some auto shop or dealer to read the tcm codes as it would be good to see what code it set. Then you know what circuit set the code and wont waste time on the wrong thing. Ron
Re: 604 in limp in mode [Re: Paul_Fancsali] #2095986
06/22/16 12:45 AM
06/22/16 12:45 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've had a couple of them many years ago. they would go into limp in periodically, Ck'd it the DRB and NO codes stored.
BUT the start count would be real low. On MOST I had, a new TCM fixed them.
BUT, I had one on a minivan with a cut wire under the left front fender well wiring.
Like to never figured that one out .
So, once ck'd and you don't have a stored code. Ck the start count in the TCM with the DRB
Re: 604 in limp in mode [Re: Paul_Fancsali] #2096891
06/23/16 06:18 PM
06/23/16 06:18 PM
P
P
Well the Dodge dealer got it and said TCM is bad oh well you never know I will see what happens tomorrow when they install it
