Page 3 of 3 1 2 3
Re: My engine likes too much timing, what to do? [Re: MR_P_BODY] #2089907
06/11/16 12:09 AM
06/11/16 12:09 AM
Champion City
The Sphinx Offline OP
Champion City
Originally Posted By MR_P_BODY
Originally Posted By The Sphinx
Originally Posted By DARTH V8Я
4 degrees got you 3/10ths & 4mph? You sure your not running crazy lean?
Spark plug says no
This is JMO.. but you have 2 problems..the wires are
backwards and your light isnt working well with the MDS
wave
Once I get through a couple graduation parties, im going to swap the wires and get me a new timing light
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089947
06/11/16 01:04 AM
06/11/16 01:04 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Still very fuzzy on the explanation, but I agree totally with dial back timing lights and msd boxes. The (M)ultiple (S)park (D)ischarge stops happening at about the rpm that you are checking it (3000rpm) Depending on the inductive circuitry in the timing light, this may be why you are seeing unusual readings. Try going to 4000rpm and see what your light tells you. At 4000 you should only be getting one spark per cycle and that may make life on your timing light easier.
Re: My engine likes too much timing, what to do? [Re: Monte_Smith] #2089956
06/11/16 01:23 AM
06/11/16 01:23 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By Monte_Smith
Probably not a popular opinion......BUT, if your motor won't run without what is considered extremely large amounts of spark lead, something in the combo is grossly inefficient.
Don't care whos motor made what, with how much timing. When there are motors with good heads and the right cam profile that make best power at around 30*......if yours needs 40*, it's NOT an efficient motor. If you have an inherently inefficient head design, there ARE cam profiles to help it.
And NO, timing is not just a number. It's a relative gauge of the engines efficiency.
In the OPs case......he has a 60s or 70s at best camshaft profile, with a modern head. Of course it's not an ideal combo
So I guess he should rebuild his combo instead of running more timing, makes sense... Lol If the motor needs more timing to make peak power run it there, that's what this combo of parts wants, I don't care if it not the most efficient it's what the person has.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089990
06/11/16 02:44 AM
06/11/16 02:44 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It doesn't matter what he does.........the POINT was, if it needs that much timing to run, it's a bad combo. If he is good with it fine, but a cam change might make a world of difference and it make a lot MORE power. Guys change parts all the time. Maybe he doesn't KNOW that if it needs that much timing, it's not very efficient..........Now he does and might want to change something.......or maybe not. Why does it hurt to point it out. He seems perplexed it needs this much......well here is why
Re: My engine likes too much timing, what to do? [Re: Monte_Smith] #2090014
06/11/16 05:18 AM
06/11/16 05:18 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Just asking, but are you driving it back to the pits before you pull the plugs? Won't that just show what it's doing on the idle circuit?
Re: My engine likes too much timing, what to do? [Re: slantzilla] #2090912
06/12/16 10:56 PM
06/12/16 10:56 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The reluctor may be of poor quality (or vibration related ignition firing scatter) such that most or all other cylinders are firing late.
If you have a damper with marks all the way around (or 360 degree timing tape) you can see how all the other cyliders compare. If not, at least look at #6 and see how it compares to #1. Number 1 and 6 line up at same point on damper since #6 is half way thru firing order.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Page 3 of 3 1 2 3
