Re: My engine likes too much timing, what to do?
[Re: The Sphinx]
#2089697
06/10/16 04:12 PM
06/10/16 04:12 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Probably not a popular opinion......BUT, if your motor won't run without what is considered extremely large amounts of spark lead, something in the combo is grossly inefficient.
Don't care whos motor made what, with how much timing. When there are motors with good heads and the right cam profile that make best power at around 30*......if yours needs 40*, it's NOT an efficient motor. If you have an inherently inefficient head design, there ARE cam profiles to help it.
And NO, timing is not just a number. It's a relative gauge of the engines efficiency.
In the OPs case......he has a 60s or 70s at best camshaft profile, with a modern head. Of course it's not an ideal combo
[Re: The Sphinx]
#2089708
06/10/16 04:41 PM
06/10/16 04:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My buddy had this happen to him once. He used one of those timing lights with the knob on the back. Looked legit with a regular light. His was off. Interesting, sounds like my timing light. I'll try another. Your running MSD, correct... MSD even suggest to not use a dial back light... I have seen them off but some guys say they work fine.... myself I use the Flaming River 1001 https://www.summitracing.com/parts/fla-fr1001/overview/
[Re: Monte_Smith]
#2089717
06/10/16 05:02 PM
06/10/16 05:02 PM
Posts: 656 Florida
CJD AUTOMOTIVE
...And NO, timing is not just a number. It's a relative gauge of the engines efficiency.
Wanted to say it, but was waiting for someone with clout that won't start an argument. 40 degrees....time to hop into the 21st century and say hello to chamber/port/combustion efficiencies in the 20 degree range....don't even get me started on the porting an iron head thread...
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: The Sphinx]
#2089775
06/10/16 07:20 PM
06/10/16 07:20 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
Had a craftsman dial back forever. It works great
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Uncle Barry]
#2089781
06/10/16 07:31 PM
06/10/16 07:31 PM
MR_P_BODY
Definitely try another timing light. IMO dial backs are garbage. See what I said..some like the dial back... but yet MSD says DONT USE THEM... that Flaming River is the best I own. and I have a FEW.. no battery to hook up.. clip it on the wire(it makes a difference which way its pointed)
[Re: B3422W5]
#2089796
06/10/16 08:27 PM
06/10/16 08:27 PM
Posts: 591 Champion City
The Sphinx
Champion City
Had a craftsman dial back forever. It works great Thats the one I have
[Re: MR_P_BODY]
#2089799
06/10/16 08:32 PM
06/10/16 08:32 PM
Posts: 4,457 Washington
madscientist
Washington
Definitely try another timing light. IMO dial backs are garbage. See what I said..some like the dial back... but yet MSD says DONT USE THEM... that Flaming River is the best I own. and I have a FEW.. no battery to hook up.. clip it on the wire(it makes a difference which way its pointed) I have a couple of timing lights..one Craftsman and one other one. Neither are dial backs. IMO those were made for mechanics working on Hondas and toyotas. Thinking about a FR light. Just never needed it. But I may get one and check it against what I have. The OP needs to get a timing light and stick with it. If you pay me to do your tune up, I do it with my timing light because I trust it, and the check it with yours. If the numbers are different then you use YOUR timing light. I don't care if your light says it has 60 total, as long as it repeats. Or you have to get a different light and check the new one.
[Re: MR_P_BODY]
#2089803
06/10/16 08:47 PM
06/10/16 08:47 PM
Monte_Smith
North Alabama
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong? Could be any of the above... swap the wires at the dist first and see if the timing drops Even though the cable is GI proof its worth a shot There was a bunch of those cable made backwards... cut them and try it worst case you you solder it with some shrink tubing... one way it picks up on the leading edge the other way it picks up on the trailing edge It's NOT that the cables are made backwards......its because one way is correct for analog and one way is correct for digital. So you check the timing, swap the wires and check it again. The higher reading is the correct connection for a digital box, the lower number is wired correctly for analog. I have seen it be 6* different........so what you read as 41* with a light, may in fact only be 36* or so
[Re: Monte_Smith]
#2089804
06/10/16 08:48 PM
06/10/16 08:48 PM
The Sphinx
Champion City
In the OPs case......he has a 60s or 70s at best camshaft profile, with a modern head. Of course it's not an ideal combo Its a 78 block .030 over with speedpro piston .005 inthe hole. With the timing gear lined up dot to dot, I checked the centerline on the cam and the opening and closing of the intake and exhaust lifters. Everything matched up with the cam card. I left it there instead of advancing the cam. The eddyheads have been gone through by Best Machine, and the MP .557 cam although and old design, plenty of people running them here making power. First run off the trailer the car ran a 12.60 @ 103 mph. Timing at 36. Jetting up on the next pass got me a 12.53 @ 105. Now at 40 degrees I ran a 12.20 @ 109.
[Re: The Sphinx]
#2089808
06/10/16 08:52 PM
06/10/16 08:52 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
4 degrees got you 3/10ths & 4mph? You sure your not running crazy lean?
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: The Sphinx]
#2089818
06/10/16 09:07 PM
06/10/16 09:07 PM
Monte_Smith
North Alabama
I generally don't bring this up, because NHRA stockers are some of the most scienced out race cars on the planet........BUT it is worth a comparison.
H/SA is where low compression 360 Volares run, that weigh 3500lbs. Stock head castings, stock lift on the shaft, stock intake and other things. The record in the class is bottom 11s at 116 mph. Your car would NEVER be as quick, because it doesn't work like a stocker. But mph is a function of POWER. With alum heads, big cam, better intake and better carb, you are 7mph down. That's a lot of power you are not making, compared to something with a whole lot closer to stock parts than you have.
So whats my point?...........the comment about "plenty of people here running that cam and making power".......OK, but do they make the power they SHOULD. That is the question. Just because so and so makes power with X part, does not mean that's the part YOU need
[Re: Monte_Smith]
#2089871
06/10/16 11:17 PM
06/10/16 11:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
[/quote]It's NOT that the cables are made backwards......its because one way is correct for analog and one way is correct for digital. So you check the timing, swap the wires and check it again. The higher reading is the correct connection for a digital box, the lower number is wired correctly for analog. I have seen it be 6* different........so what you read as 41* with a light, may in fact only be 36* or so[/quote]
I get the actual timing change in spark output with switching the wires, but I'm not following how 41 would be seen as 36. It seems to me that if the polarity were to be switched, and in fact the timing did drop to 36, wouldn't he now have to bump up the timing to get the engine to run at its best? Not trying to argue, just trying to figure out the end logic.
[Re: 1967dartgt]
#2089877
06/10/16 11:28 PM
06/10/16 11:28 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
1967Dartgt which engine masters motor? Yours! Thanks 1967dartgt, I thought that was the case,that is why I asked. I have been hoping to get in the 6teens I guess I should move my timing up and see if it helps. I have been running 35* timing. I have been waiting on my 315/60 Radial Pros I ordered from Summit for 6 weeks and now they say it will be the 24th.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: TRENDZ]
#2089881
06/10/16 11:33 PM
06/10/16 11:33 PM
MR_P_BODY
[/quote]It's NOT that the cables are made backwards......its because one way is correct for analog and one way is correct for digital. So you check the timing, swap the wires and check it again. The higher reading is the correct connection for a digital box, the lower number is wired correctly for analog. I have seen it be 6* different........so what you read as 41* with a light, may in fact only be 36* or so I get the actual timing change in spark output with switching the wires, but I'm not following how 41 would be seen as 36. It seems to me that if the polarity were to be switched, and in fact the timing did drop to 36, wouldn't he now have to bump up the timing to get the engine to run at its best? Not trying to argue, just trying to figure out the end logic. [/quote] On my engine 416 it made the best power at 40*.. he is at 41 but afraid to go higher.. so IF the wires are backwards at its really at 36* he could still go higher for peak power and it wouldnt read 47*.. the number would end up lower... he has already said if he goes higher it runs better.. it needs the timing.. no matter what the number is... but 47* or what ever it turns out to be is a high number.... so IF his light is off AND the wires are backwards that would mean a lot... also he said he went to 3000 rpm.. if he was a little low that would still have the multiy spark working... that drops out at 3000 rpm +or-
[Re: DARTH V8Я]
#2089882
06/10/16 11:34 PM
06/10/16 11:34 PM
The Sphinx
Champion City
4 degrees got you 3/10ths & 4mph? You sure your not running crazy lean? Spark plug says no
[Re: The Sphinx]
#2089888
06/10/16 11:44 PM
06/10/16 11:44 PM
MR_P_BODY
4 degrees got you 3/10ths & 4mph? You sure your not running crazy lean? Spark plug says no This is JMO.. but you have 2 problems..the wires are backwards and your light isnt working well with the MDS
