Best Water Pump #2089062
06/09/16 02:05 PM
06/09/16 02:05 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
What's the best water pump to use on a warmed up daily driven 318? I was looking at getting the Milodon 16250 for this application... will be driven hard and in Florida (Hot). Also, I'm having a heck of a time finding a brass 3 row radiator that fits my '82 Gran Fury (M-Body) everything I see is the plastic tank/aluminum crap
Re: Best Water Pump [Re: jeebis44] #2089129
06/09/16 03:39 PM
06/09/16 03:39 PM
get a parts house 8 blader (non AC) & you will be fine. cut an anticav plate on it if desired. I cut one out of the side of an old washing machine. cut the OD slightly less than the OD of the blade tips so you can tack several of em and drill a center hole & tack it there too. concentrate on a good 3 row and an MP clutch fan with 7 blades properly postitioned into a schroud with a 180 stat and proper pulley ratio. #1 need good airflow
Re: Best Water Pump [Re: RapidRobert] #2089157
06/09/16 04:24 PM
06/09/16 04:24 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
I found the flow cooler pumps to be superior. I did a comparison of stock so called high flow and flow cooler pumps. Only the flow cooler had a special impeller design. This was for the cast iron early style LA motor.
Re: Best Water Pump [Re: jeebis44] #2089376
06/09/16 10:51 PM
06/09/16 10:51 PM
BlueRacer69 Offline
BlueRacer69  Offline
Same here, Flow Cooler. Nice pump.
Re: Best Water Pump [Re: BlueRacer69] #2089486
06/10/16 02:00 AM
06/10/16 02:00 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Edelbrock pumps have a steel disc that takes up the entire opening on the timing cover and they have long curved blades with a lot of surface area to move more water volume per revolution. They work great, but they do cost more than the others.
Re: Best Water Pump [Re: Neil] #2089594
06/10/16 12:22 PM
06/10/16 12:22 PM
agreed, the aftermarket pumps flow more IF NEEDED, & are pricey which I wouldn't think would be needed in this app. find a good radiator! I'd get a Champion 3 row from the guy on here who sells (& guarantees em). my Champion 2 row (eBay) was 189 to my door
Re: Best Water Pump [Re: jeebis44] #2089622
06/10/16 01:37 PM
06/10/16 01:37 PM
st.louis mo
satjoe Offline
satjoe  Offline
st.louis mo
i bought a moroso one. it was a gnb with a steel disc on the back. it works great, but I can buy a gnb from autozone or advance and do the same mods myself, and save money.
Re: Best Water Pump [Re: jeebis44] #2089764
06/10/16 07:01 PM
06/10/16 07:01 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've had very good results with GNB pumps.
Nautilus Racing-
Re: Best Water Pump [Re: jeebis44] #2089774
06/10/16 07:17 PM
06/10/16 07:17 PM
Tacoma, Washington USA
Adam71Charger Offline
flowkooler
